Originally posted by rjh
View Post
Issue checking child device, parent does not reference this child.
Can you try HS3 build 521, I assume you are on Windows?
Go into Setup, Labs tab, and click on the Fix Relationships button then restart HS and see if there are any warnings in the log.
I would back up your HS3 folder just in case, I only tested this on one system that had some problems.
htp://homeseer.com/updates3/SetupHS3_3_0_0_521.msi
Originally posted by mwaite View Post
Well that explains why I'm having issues with HS Mobile. What can I do to fix this? WIth 1000+ devices starting over is not much of an option for me.
I only started getting these warnings with the .518 build I believe.
Originally posted by rjh View PostThere is no way to edit the parent/child relationship in HS right now, so no easy way to fix it currently. I do have code that tries to put things back. What I can do is add this code to the "Labs" page in Setup so you can run it when you need to. We can see if that fixes things. Its possible there is not enough information to put things back. Will let you know when that is ready to try.
The code never intended to support multiple parents, so while it may make sense for a use case, I think it may be a mess in the code. Can you tell me why you would want this? A device is suppose to represent a single piece of hardware and child devices are features.
Originally posted by bsobel View Post
rjh I was meaning to follow-up with you on this. Can I suggest a new bit flag for the relationships (something like multiparent?) Allow this to be set on the child devices if they are in the ISY case where multiple parents make sense. This way you can filter those out in HsMobile and in your sanity checks but keep the functionality for those that it makes sense for (disconnecting the ISY Scenes from their members will make the devices page a bit hard to navigate, IMHO).
Originally posted by rjh View PostOdd that you are seeing so many devices with parent/child relationship issues. I am not sure how it got like that. We have code that will fix this, but adding it breaks some plugins. Hopefully we can get the plugins on track and then we can add the code back in to fix the associations. In your case I doubt HomeSeer Mobile will display things properly.
Steve
Originally posted by prsmith777 View PostSDJHealth plugin is affected per my startup log
Steve
Originally posted by bsobel View PostRich was planning on changes to enforce the parent/child relationships, but that could break some plugin like the ISYInsteon one. I connected Bob and Rich and they were discussing how to best handle, Rich was going to publish some guidelines as well as this likely effects multiple plugins. Right now its simply logging the cases that violate how HS wants to enforce, but no enforcement is happened (e.g. you can ignore them for now). But the plugin authors involved probably need to give their opinion to Rich on the proposed changes.
What Rich wants is a string parent/child relationship. So if a child device has a parent, it should be set as a parent device and include the child in its child list. And a child could have only one parent. With ISY scenes makes a fairly natural parent to a device, but a device can be in multiple scenes (hence have multiple parents). Its this one parent vs multiple parents that is the root issue of the logging you are seeing.
I get these warnings whenever I restart HS. This started the last couple of builds (testing the log lockup issue), I'm not sure if it's build related or something else is going on. Seems it's pretty much every device on my system, not device-type related. I don't see any ill-affect on my system, but it's very disturbing. rjh, any chance something in the recent couple of builds is causing this?
Mar-11 9:41:13 AM Warning Device (641) Z-Wave Living Room Switch Multilevel 5 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (641) Z-Wave Living Room Switch Multilevel 5 Mar-11 9:41:13 AM Warning Device (640) Z-Wave Living Room Color Control Custom RGB 5 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (640) Z-Wave Living Room Color Control Custom RGB 5 Mar-11 9:41:13 AM Warning Device (639) Z-Wave Living Room Blue 5 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (639) Z-Wave Living Room Blue 5 Mar-11 9:41:13 AM Warning Device (638) Z-Wave Living Room Green 5 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (638) Z-Wave Living Room Green 5 Mar-11 9:41:13 AM Warning Device (637) Z-Wave Living Room Red 5 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (637) Z-Wave Living Room Red 5 Mar-11 9:41:13 AM Warning Device (636) Z-Wave Living Room Cold_White 5 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (636) Z-Wave Living Room Cold_White 5 Mar-11 9:41:13 AM Warning Device (635) Z-Wave Living Room Warm_White 5 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (635) Z-Wave Living Room Warm_White 5 Mar-11 9:41:13 AM Warning Device (633) Z-Wave Living Room Switch Multilevel 4 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (633) Z-Wave Living Room Switch Multilevel 4 Mar-11 9:41:13 AM Warning Device (632) Z-Wave Living Room Color Control Custom RGB 4 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (632) Z-Wave Living Room Color Control Custom RGB 4 Mar-11 9:41:13 AM Warning Device (631) Z-Wave Living Room Blue 4 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (631) Z-Wave Living Room Blue 4 Mar-11 9:41:13 AM Warning Device (630) Z-Wave Living Room Green 4 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (630) Z-Wave Living Room Green 4 Mar-11 9:41:13 AM Warning Device (629) Z-Wave Living Room Red 4 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (629) Z-Wave Living Room Red 4 Mar-11 9:41:13 AM Warning Device (628) Z-Wave Living Room Cold_White 4 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (628) Z-Wave Living Room Cold_White 4 Mar-11 9:41:13 AM Warning Device (627) Z-Wave Living Room Warm_White 4 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (627) Z-Wave Living Room Warm_White 4 Mar-11 9:41:13 AM Warning Device (625) Z-Wave Living Room Switch Multilevel 3 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (625) Z-Wave Living Room Switch Multilevel 3 Mar-11 9:41:13 AM Warning Device (624) Z-Wave Living Room Color Control Custom RGB 3 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (624) Z-Wave Living Room Color Control Custom RGB 3 Mar-11 9:41:13 AM Warning Device (623) Z-Wave Living Room Blue 3 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (623) Z-Wave Living Room Blue 3 Mar-11 9:41:13 AM Warning Device (622) Z-Wave Living Room Green 3 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (622) Z-Wave Living Room Green 3 Mar-11 9:41:13 AM Warning Device (621) Z-Wave Living Room Red 3 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (621) Z-Wave Living Room Red 3 Mar-11 9:41:13 AM Warning Device (620) Z-Wave Living Room Cold_White 3 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (620) Z-Wave Living Room Cold_White 3 Mar-11 9:41:13 AM Warning Device (619) Z-Wave Living Room Warm_White 3 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (619) Z-Wave Living Room Warm_White 3 Mar-11 9:41:13 AM Warning Device (617) Z-Wave Living Room Switch Multilevel 2 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (617) Z-Wave Living Room Switch Multilevel 2 Mar-11 9:41:13 AM Warning Device (616) Z-Wave Living Room Color Control Custom RGB 2 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (616) Z-Wave Living Room Color Control Custom RGB 2 Mar-11 9:41:13 AM Warning Device (615) Z-Wave Living Room Blue 2 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (615) Z-Wave Living Room Blue 2 Mar-11 9:41:13 AM Warning Device (614) Z-Wave Living Room Green 2 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (614) Z-Wave Living Room Green 2 Mar-11 9:41:13 AM Warning Device (613) Z-Wave Living Room Red 2 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (613) Z-Wave Living Room Red 2 Mar-11 9:41:13 AM Warning Device (612) Z-Wave Living Room Cold_White 2 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (612) Z-Wave Living Room Cold_White 2 Mar-11 9:41:13 AM Warning Device (611) Z-Wave Living Room Warm_White 2 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (611) Z-Wave Living Room Warm_White 2 Mar-11 9:41:13 AM Warning Device (586) Z-Wave Living Room Color Control Custom RGB 1 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (586) Z-Wave Living Room Color Control Custom RGB 1 Mar-11 9:41:13 AM Warning Device (585) Z-Wave Living Room Blue 1 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (585) Z-Wave Living Room Blue 1 Mar-11 9:41:13 AM Warning Device (584) Z-Wave Living Room Green 1 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (584) Z-Wave Living Room Green 1 Mar-11 9:41:13 AM Warning Device (583) Z-Wave Living Room Red 1 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (583) Z-Wave Living Room Red 1 Mar-11 9:41:13 AM Warning Device (582) Z-Wave Living Room Cold_White 1 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (582) Z-Wave Living Room Cold_White 1 Mar-11 9:41:13 AM Warning Device (581) Z-Wave Living Room Warm_White 1 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (581) Z-Wave Living Room Warm_White 1 Mar-11 9:41:13 AM Warning Device (580) Z-Wave Living Room Switch Multilevel 1 references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (580) Z-Wave Living Room Switch Multilevel 1 Mar-11 9:41:13 AM Warning Device (569) Z-Wave Kitchen Smoke/CO2 Detector Notification references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (569) Z-Wave Kitchen Smoke/CO2 Detector Notification Mar-11 9:41:13 AM Warning Device (568) Z-Wave Kitchen Smoke/CO2 Detector Battery references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (568) Z-Wave Kitchen Smoke/CO2 Detector Battery Mar-11 9:41:13 AM Warning Device (565) Virtual Family Room Ceiling Fan HOLD references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (565) Virtual Family Room Ceiling Fan HOLD Mar-11 9:41:13 AM Warning Device (2659) ISY House All Lights is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (531) ISY Wine Cellar Arch LEDs Mar-11 9:41:13 AM Warning Device (476) Z-Wave Outside Side Gate Sensor Binary references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (476) Z-Wave Outside Side Gate Sensor Binary Mar-11 9:41:13 AM Warning Device (475) Z-Wave Outside Side Gate Battery references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (475) Z-Wave Outside Side Gate Battery Mar-11 9:41:13 AM Warning Device (444) Z-Wave Wine Cellar Aeon Labs Switch Binary Node 29 Child references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (444) Z-Wave Wine Cellar Aeon Labs Switch Binary Node 29 Child Mar-11 9:41:13 AM Warning Device (443) Z-Wave Wine Cellar Aeon Labs Power Node 29 Child references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (443) Z-Wave Wine Cellar Aeon Labs Power Node 29 Child Mar-11 9:41:13 AM Warning Device (442) Z-Wave Wine Cellar Aeon Labs Watts Node 29 Child references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (442) Z-Wave Wine Cellar Aeon Labs Watts Node 29 Child Mar-11 9:41:13 AM Warning Device (441) Z-Wave Wine Cellar Aeon Labs kW Hours Node 29 Child references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (441) Z-Wave Wine Cellar Aeon Labs kW Hours Node 29 Child Mar-11 9:41:13 AM Warning Device (3478) Jon00Net Jon00 Network BlueIris is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3477) Jon00Net Jon00 Network Cellar-PC is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3476) Jon00Net Jon00 Network Plex is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3475) Jon00Net Jon00 Network GarageIGMA is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3474) Jon00Net Jon00 Network Office is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3470) Jon00Net Jon00 Network SeneyeSWS is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3457) Jon00Net Jon00 Network Cam-PorchAmcrest is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3455) Jon00Net Jon00 Network Chevy iPad is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3454) Jon00Net Jon00 Network HarmonyHub-FR is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3453) Jon00Net Jon00 Network WaterCannon is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3452) Jon00Net Jon00 Network MB Apple-TV is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3450) Jon00Net Jon00 Network Amazon Show is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3448) Jon00Net Jon00 Network Meural Frame is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3447) Jon00Net Jon00 Network Orbi Satellite-Garage is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3446) Jon00Net Jon00 Network Brother Printer is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3445) Jon00Net Jon00 Network MytMyk-iPadPro is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3444) Jon00Net Jon00 Network Sony PS4 is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3443) Jon00Net Jon00 Network Visio TV is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3442) Jon00Net Jon00 Network MytMyk-iPhone-X is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3440) Jon00Net Jon00 Network LG IOT-1 is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3438) Jon00Net Jon00 Network Neato-D7 is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3437) Jon00Net Jon00 Network MytQubeCortet is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3436) Jon00Net Jon00 Network SolarEdge is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3435) Jon00Net Jon00 Network NeatoBotvacConnected is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3434) Jon00Net Jon00 Network Orbi Satellite-1 is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3433) Jon00Net Jon00 Network LG IOT is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3432) Jon00Net Jon00 Network Echo-Bedroom is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3431) Jon00Net Jon00 Network Echo-Kitchen is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3430) Jon00Net Jon00 Network Cam-GarBack is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3427) Jon00Net Jon00 Network XenServer is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3424) Jon00Net Jon00 Network Netgear Orb Router is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3418) Jon00Net Jon00 Network Aruba Router is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3417) Jon00Net Jon00 Network MB FireTV is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3416) Jon00Net Jon00 Network Slingbox is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3415) Jon00Net Jon00 Network ZNet is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3414) Jon00Net Jon00 Network MB_Harmony_Hub is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3413) Jon00Net Jon00 Network Yamaha RX-A3050 is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3412) Jon00Net Jon00 Network Cam-Clyde is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3411) Jon00Net Jon00 Network ifnrule is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3410) Jon00Net Jon00 Network Cam-Bkyard is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3409) Jon00Net Jon00 Network RFXCom is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3408) Jon00Net Jon00 Network ISY994i is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3407) Jon00Net Jon00 Network ESXi is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3406) Jon00Net Jon00 Network Synology is not marked as child, but parent device 3419 includes it as a child Mar-11 9:41:13 AM Warning Issue checking parent device (3419) Utility Jon00 Network Root Mar-11 9:41:13 AM Warning Device (3394) Zone does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3394) Zone Mar-11 9:41:13 AM Warning Device (3097) Neato Upstairs ExtraInfo does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3097) Neato Upstairs ExtraInfo Mar-11 9:41:13 AM Warning Device (3096) Neato Upstairs Mode does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3096) Neato Upstairs Mode Mar-11 9:41:13 AM Warning Device (3095) Neato Upstairs Modifier does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3095) Neato Upstairs Modifier Mar-11 9:41:13 AM Warning Device (3094) Neato Upstairs LaunchedFrom does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3094) Neato Upstairs LaunchedFrom Mar-11 9:41:13 AM Warning Device (3093) Neato Upstairs Category does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3093) Neato Upstairs Category Mar-11 9:41:13 AM Warning Device (3092) Neato Upstairs BatteryUsed does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3092) Neato Upstairs BatteryUsed Mar-11 9:41:13 AM Warning Device (3091) Neato Upstairs Error does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3091) Neato Upstairs Error Mar-11 9:41:13 AM Warning Device (3090) Neato Upstairs Status does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3090) Neato Upstairs Status Mar-11 9:41:13 AM Warning Device (3089) Neato Upstairs CleanedArea does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3089) Neato Upstairs CleanedArea Mar-11 9:41:13 AM Warning Device (3088) Neato Upstairs Duration does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3088) Neato Upstairs Duration Mar-11 9:41:13 AM Warning Device (3087) Neato Upstairs Start does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3087) Neato Upstairs Start Mar-11 9:41:13 AM Warning Device (3086) Neato Upstairs Map does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3086) Neato Upstairs Map Mar-11 9:41:13 AM Warning Device (3097) Neato Upstairs ExtraInfo is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3096) Neato Upstairs Mode is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3095) Neato Upstairs Modifier is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3094) Neato Upstairs LaunchedFrom is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3093) Neato Upstairs Category is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3092) Neato Upstairs BatteryUsed is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3091) Neato Upstairs Error is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3090) Neato Upstairs Status is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3089) Neato Upstairs CleanedArea is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3088) Neato Upstairs Duration is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3087) Neato Upstairs Start is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3086) Neato Upstairs Map is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3085) Neato Upstairs Upstairs Neato maps Mar-11 9:41:13 AM Warning Device (3084) Neato Upstairs SpotHeight does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3084) Neato Upstairs SpotHeight Mar-11 9:41:13 AM Warning Device (3083) Neato Upstairs SpotWidth does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3083) Neato Upstairs SpotWidth Mar-11 9:41:13 AM Warning Device (3082) Neato Upstairs Modifier does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3082) Neato Upstairs Modifier Mar-11 9:41:13 AM Warning Device (3081) Neato Upstairs Mode does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3081) Neato Upstairs Mode Mar-11 9:41:13 AM Warning Device (3080) Neato Upstairs Error does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3080) Neato Upstairs Error Mar-11 9:41:13 AM Warning Device (3079) Neato Upstairs Alert does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3079) Neato Upstairs Alert Mar-11 9:41:13 AM Warning Device (3078) Neato Upstairs Battery does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3078) Neato Upstairs Battery Mar-11 9:41:13 AM Warning Device (3077) Neato Upstairs Dustbin does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3077) Neato Upstairs Dustbin Mar-11 9:41:13 AM Warning Device (3076) Neato Upstairs Dock does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3076) Neato Upstairs Dock Mar-11 9:41:13 AM Warning Device (3075) Neato Upstairs Action does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3075) Neato Upstairs Action Mar-11 9:41:13 AM Warning Device (3074) Neato Upstairs Status does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3074) Neato Upstairs Status Mar-11 9:41:13 AM Warning Device (3084) Neato Upstairs SpotHeight is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3083) Neato Upstairs SpotWidth is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3082) Neato Upstairs Modifier is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3081) Neato Upstairs Mode is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3080) Neato Upstairs Error is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3079) Neato Upstairs Alert is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3078) Neato Upstairs Battery is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3077) Neato Upstairs Dustbin is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3076) Neato Upstairs Dock is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3075) Neato Upstairs Action is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3074) Neato Upstairs Status is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3073) Neato Upstairs Upstairs Neato Mar-11 9:41:13 AM Warning Device (3072) Neato Downstairs ExtraInfo does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3072) Neato Downstairs ExtraInfo Mar-11 9:41:13 AM Warning Device (3071) Neato Downstairs NavigationMode does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3071) Neato Downstairs NavigationMode Mar-11 9:41:13 AM Warning Device (3070) Neato Downstairs Mode does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3070) Neato Downstairs Mode Mar-11 9:41:13 AM Warning Device (3069) Neato Downstairs LaunchedFrom does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3069) Neato Downstairs LaunchedFrom Mar-11 9:41:13 AM Warning Device (3068) Neato Downstairs Category does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3068) Neato Downstairs Category Mar-11 9:41:13 AM Warning Device (3067) Neato Downstairs BatteryUsed does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3067) Neato Downstairs BatteryUsed Mar-11 9:41:13 AM Warning Device (3066) Neato Downstairs Error does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3066) Neato Downstairs Error Mar-11 9:41:13 AM Warning Device (3065) Neato Downstairs Status does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3065) Neato Downstairs Status Mar-11 9:41:13 AM Warning Device (3064) Neato Downstairs CleanedArea does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3064) Neato Downstairs CleanedArea Mar-11 9:41:13 AM Warning Device (3063) Neato Downstairs Duration does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3063) Neato Downstairs Duration Mar-11 9:41:13 AM Warning Device (3062) Neato Downstairs Start does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3062) Neato Downstairs Start Mar-11 9:41:13 AM Warning Device (3061) Neato Downstairs Map does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3061) Neato Downstairs Map Mar-11 9:41:13 AM Warning Device (3072) Neato Downstairs ExtraInfo is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3071) Neato Downstairs NavigationMode is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3070) Neato Downstairs Mode is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3069) Neato Downstairs LaunchedFrom is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3068) Neato Downstairs Category is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3067) Neato Downstairs BatteryUsed is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3066) Neato Downstairs Error is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3065) Neato Downstairs Status is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3064) Neato Downstairs CleanedArea is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3063) Neato Downstairs Duration is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3062) Neato Downstairs Start is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3061) Neato Downstairs Map is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3060) Neato Downstairs Downstairs Neato-D7 maps Mar-11 9:41:13 AM Warning Device (3059) Neato Downstairs BrushChangeReminder does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3059) Neato Downstairs BrushChangeReminder Mar-11 9:41:13 AM Warning Device (3058) Neato Downstairs FilterChangeReminder does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3058) Neato Downstairs FilterChangeReminder Mar-11 9:41:13 AM Warning Device (3057) Neato Downstairs DirtbinAlertReminder does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3057) Neato Downstairs DirtbinAlertReminder Mar-11 9:41:13 AM Warning Device (3059) Neato Downstairs BrushChangeReminder is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3056) Neato Downstairs Downstairs Neato-D7 settings Mar-11 9:41:13 AM Warning Device (3058) Neato Downstairs FilterChangeReminder is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3056) Neato Downstairs Downstairs Neato-D7 settings Mar-11 9:41:13 AM Warning Device (3057) Neato Downstairs DirtbinAlertReminder is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3056) Neato Downstairs Downstairs Neato-D7 settings Mar-11 9:41:13 AM Warning Device (3055) Neato Downstairs SpotHeight does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3055) Neato Downstairs SpotHeight Mar-11 9:41:13 AM Warning Device (3054) Neato Downstairs SpotWidth does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3054) Neato Downstairs SpotWidth Mar-11 9:41:13 AM Warning Device (3053) Neato Downstairs NavigationMode does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3053) Neato Downstairs NavigationMode Mar-11 9:41:13 AM Warning Device (3052) Neato Downstairs Mode does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3052) Neato Downstairs Mode Mar-11 9:41:13 AM Warning Device (3051) Neato Downstairs Error does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3051) Neato Downstairs Error Mar-11 9:41:13 AM Warning Device (3050) Neato Downstairs Alert does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3050) Neato Downstairs Alert Mar-11 9:41:13 AM Warning Device (3049) Neato Downstairs Battery does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3049) Neato Downstairs Battery Mar-11 9:41:13 AM Warning Device (3048) Neato Downstairs Dustbin does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3048) Neato Downstairs Dustbin Mar-11 9:41:13 AM Warning Device (3047) Neato Downstairs Dock does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3047) Neato Downstairs Dock Mar-11 9:41:13 AM Warning Device (3046) Neato Downstairs Action does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3046) Neato Downstairs Action Mar-11 9:41:13 AM Warning Device (3045) Neato Downstairs Status does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (3045) Neato Downstairs Status Mar-11 9:41:13 AM Warning Device (3394) Zone is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3055) Neato Downstairs SpotHeight is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3054) Neato Downstairs SpotWidth is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3053) Neato Downstairs NavigationMode is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3052) Neato Downstairs Mode is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3051) Neato Downstairs Error is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3050) Neato Downstairs Alert is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3049) Neato Downstairs Battery is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3048) Neato Downstairs Dustbin is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3047) Neato Downstairs Dock is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3046) Neato Downstairs Action is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (3045) Neato Downstairs Status is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (3044) Neato Downstairs Downstairs Neato-D7 Mar-11 9:41:13 AM Warning Device (2659) ISY House All Lights does not reference a parent, or references too many parents Mar-11 9:41:13 AM Warning Issue checking child device (2659) ISY House All Lights Mar-11 9:41:13 AM Warning Device (2659) ISY House All Lights is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (250) ISY Garage Light 2 Mar-11 9:41:13 AM Warning Device (247) ISY Family Room Lamp Sn does not reference a parent, or references too many parents Mar-11 9:41:13 AM Warning Issue checking child device (247) ISY Family Room Lamp Sn Mar-11 9:41:13 AM Warning Device (2659) ISY House All Lights is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (246) ISY Family Room Lamp Outlet Mar-11 9:41:13 AM Warning Device (247) ISY Family Room Lamp Sn is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (246) ISY Family Room Lamp Outlet Mar-11 9:41:13 AM Warning Device (243) ISY Kitchen Island Lights Sn does not reference a parent, or references too many parents Mar-11 9:41:13 AM Warning Issue checking child device (243) ISY Kitchen Island Lights Sn Mar-11 9:41:13 AM Warning Device (2338) ISY Family Room Garage Door is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (2346) ISY Garage Door Mar-11 9:41:13 AM Warning Device (215) ISY Garage Door Switch -Relay is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (2346) ISY Garage Door Mar-11 9:41:13 AM Warning Device (2341) ISY Family Room Lamp does not reference a parent, or references too many parents Mar-11 9:41:13 AM Warning Issue checking child device (2341) ISY Family Room Lamp Mar-11 9:41:13 AM Warning Device (2340) ISY Family Room Island Lights does not reference a parent, or references too many parents Mar-11 9:41:13 AM Warning Issue checking child device (2340) ISY Family Room Island Lights Mar-11 9:41:13 AM Warning Device (2338) ISY Family Room Garage Door does not reference a parent, or references too many parents Mar-11 9:41:13 AM Warning Issue checking child device (2338) ISY Family Room Garage Door Mar-11 9:41:13 AM Warning Device (2341) ISY Family Room Lamp is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (2337) ISY Family Room Fan Light Mar-11 9:41:13 AM Warning Device (2340) ISY Family Room Island Lights is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (2337) ISY Family Room Fan Light Mar-11 9:41:13 AM Warning Device (2338) ISY Family Room Garage Door is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (2337) ISY Family Room Fan Light Mar-11 9:41:13 AM Warning Device (2336) ISY Family Room Porch Light is marked as child, but references the wrong parent: 2345 Mar-11 9:41:13 AM Warning Issue checking parent device (2337) ISY Family Room Fan Light Mar-11 9:41:13 AM Warning Device (224) ISY Fish Light ON does not reference a parent, it should reference one parent Mar-11 9:41:13 AM Warning Issue checking child device (224) ISY Fish Light ON Mar-11 9:41:13 AM Warning Device (215) ISY Garage Door Switch -Relay does not reference a parent, or references too many parents Mar-11 9:41:13 AM Warning Issue checking child device (215) ISY Garage Door Switch -Relay Mar-11 9:41:13 AM Warning Device (215) ISY Garage Door Switch -Relay is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (213) ISY Garage Door Status -Relay Mar-11 9:41:13 AM Warning Device (1338) Virtual Backyard Phidget Heartbeat ENABLED is marked as child, but references the wrong parent: 1335 Mar-11 9:41:13 AM Warning Issue checking parent device (2046) Virtual Monitor HS3 Heartbeat Mar-11 9:41:13 AM Warning Device (1694) Utility Jon00 Uptime Chiller ON Counter is marked as child, but references the wrong parent: 1690 Mar-11 9:41:13 AM Warning Issue checking parent device (1684) Utility Jon00 Uptime HVAC Runtime Mar-11 9:41:13 AM Warning Device (1128) Z-Wave Kitchen Slider Binary references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1128) Z-Wave Kitchen Slider Binary Mar-11 9:41:13 AM Warning Device (1127) Z-Wave Kitchen Slider Battery references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1127) Z-Wave Kitchen Slider Battery Mar-11 9:41:13 AM Warning Device (1126) Z-Wave Kitchen Slider Tamper references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1126) Z-Wave Kitchen Slider Tamper Mar-11 9:41:13 AM Warning Device (1124) Z-Wave Garage Slider Binary references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1124) Z-Wave Garage Slider Binary Mar-11 9:41:13 AM Warning Device (1123) Z-Wave Garage Slider Battery references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1123) Z-Wave Garage Slider Battery Mar-11 9:41:13 AM Warning Device (1122) Z-Wave Garage Slider Tamper references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1122) Z-Wave Garage Slider Tamper Mar-11 9:41:13 AM Warning Device (1120) Z-Wave Downstairs Bathroom Sensor Binary references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1120) Z-Wave Downstairs Bathroom Sensor Binary Mar-11 9:41:13 AM Warning Device (1119) Z-Wave Downstairs Bathroom Door Battery references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1119) Z-Wave Downstairs Bathroom Door Battery Mar-11 9:41:13 AM Warning Device (1045) Z-Wave Downstairs Bathroom Vent Switch references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1045) Z-Wave Downstairs Bathroom Vent Switch Mar-11 9:41:13 AM Warning Device (1044) Z-Wave Downstairs Bathroom Vent Battery references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1044) Z-Wave Downstairs Bathroom Vent Battery Mar-11 9:41:13 AM Warning Device (1042) Z-Wave Garage Switch Binary references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1042) Z-Wave Garage Switch Binary Mar-11 9:41:13 AM Warning Device (1041) Z-Wave Garage General Purpose references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1041) Z-Wave Garage General Purpose Mar-11 9:41:13 AM Warning Device (1040) Z-Wave Garage Doorbell references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1040) Z-Wave Garage Doorbell Mar-11 9:41:13 AM Warning Device (1039) Z-Wave Garage Meter Pulse references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1039) Z-Wave Garage Meter Pulse Mar-11 9:41:13 AM Warning Device (1038) Z-Wave Garage Notification references a parent, but the parent does not reference this child Mar-11 9:41:13 AM Warning Issue checking child device (1038) Z-Wave Garage Notification Mar-11 9:41:13 AM Warning Device (2659) ISY House All Lights is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (1036) ISY Kitchen Island Lights Mar-11 9:41:13 AM Warning Device (243) ISY Kitchen Island Lights Sn is marked as child, but does not reference any parent Mar-11 9:41:13 AM Warning Issue checking parent device (1036) ISY Kitchen Island Lights Tags: None
