HS3 Crashing
  • HS3 Crashing
    I've been having HS3 crashes every few days lately, apparently related to .NET. This is a Win7 Hometroller. Event viewer message and crash data are below. Any suggestions?
    Application: HS3.exe Framework Version: v4.0.30319 Description: The process was terminated due to an internal error in the .NET Runtime at IP 6CDCFB43 (6CCE0000) with exit code 80131506.
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: HS3.exe
    Application Version: 3.0.0.500
    Application Timestamp: 5c546edd
    Fault Module Name: clr.dll
    Fault Module Version: 4.6.1055.0
    Fault Module Timestamp: 563c0f73
    Exception Code: c0000005
    Exception Offset: 000efb43
    OS Version: 6.1.7601.2.1.0.320.65
    Locale ID: 1033
    Additional Information 1: 601d
    Additional Information 2: 601d80ab34f6e44161824c30c799523f
    Additional Information 3: bdc9
    Additional Information 4: bdc9dcd5d1e55fdff7a4a2f251ea8dad
    Thanks.
    Mark
    Hometroller S6 w/ HS3Pro, Way2Call
    BLAB8SS, BL Backup, Easy Trigger, HSTouch, Open Sprinkler, SONOS, Ultra1Wire3, UltraM1G, WeatherXML, Z-Wave
    I'd start with checking and reinstalling .net. Here's one guide: https://www.raymond.cc/blog/uninstal...-cleanup-tool/
      Ugh. Not looking forward to messing with .NET again. I have brutal memory of the last time I did a repair/reinstall - things got a whole lot worse. Thanks.
      Mark
        Yup, there’s that risk. Make sure you have a good backup before you start.
          Am I reading you error report correctly that you are using a beta version v500. Might be worth using a stable release
