Homeseer crashes...how to debug?
    I am getting random crashes on a Homeseer SEL running 3.0.0.531 (though this has been happening on earlier builds as well)...there does not seem to be any pattern with them. It is happening roughly one or twice a week.
    I have HSsentry running yet it fails to restart HS every time this happens. I have been rebooting the box when this occurs. There is nothing in the HS logs that indicates a problem...the process just dies. Syslog does not show anything either.
    I am looking for some advice on if there is any additional logging/monitoring I can install to try and track down what is going on here. This is really starting to wear on the family (and me).
    thanks,
    Howie
    Try dmesg first and see if anything jumps out there.
    Also, try going to the /var/log folder and ls -lt to see if there are any logs there that will help.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      I have looked through all of the system logs and can't find anything. It is frustrating that HSSentry is not restarting the system like it is supposed to. I have a script to run an event that texts me on startup but since HSSentry is not working I have to find out about crashes by my lights or something else not working.
        I have been having the same issue for about the past month. Once or twice a week I'll come home and HS will have shot down. I went to the Windows Event Viewer > Windows Logs > Application and there is usually three sequential errors (screen shot below). It's an ASP.NET error, then a .NET Runtime, then an Application error. The details from the ASP.NET error are below. Any help would be appreciated.
        - System
        - Provider
        [ Name] ASP.NET 4.0.30319.0
        - EventID 1325
        [ Qualifiers] 49152
        Level 2
        Task 0
        Keywords 0x80000000000000
        - TimeCreated
        [ SystemTime] 2019-05-15T15:40:08.805534900Z
        EventRecordID 19349
        Channel Application
        Computer VM-893945
        Security
        - EventData
        An unhandled exception occurred and the process was terminated. Application ID: HS3.exe Process ID: 7548 Exception: System.OutOfMemoryException Message: Exception of type 'System.OutOfMemoryException' was thrown. StackTrace: at System.Net.Sockets.OverlappedAsyncResult.PostCompletion(Int3 2 numBytes) at System.Net.Sockets.BaseOverlappedAsyncResult.CompletionPortC allback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped) at System.Threading._IOCompletionCallback.PerformIOCompletionCa llback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
          I have simlar issues, with high CPU usage after X time, tried also differnet things. Disableing pluginjs, hstouch, hsphone, but stille happening. No apparent messages in LOG and Win Eventlog.
          Regards Bart
          Win7 64Bit on Intel NUCI7 with SSD
          HSPRO 3.
          Devices; 1370 Events; 691
          Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
          Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
            Another HS crash today. I have no idea when or why. I find it hard to believe that nothing gets logged but that is what is happening.
            Does anyone have any idea how to track this down? Is there a more detailed level of logging I can enable for Homeseer?
            Anybody from Homeseer have any suggestions?
              You can enable debug logging by setting DebugMode to the proper value.
              https://homeseer.com/support/homesee..._debugmode.htm
              Len
              Linux version: Linux homeseer Ubuntu 16.04 x86_64
              Number of Devices: 633
              Number of Events: 773
              Enabled Plug-Ins
              2.0.54.0: BLBackup
              2.0.40.0: BLLAN
              3.0.0.48: EasyTrigger
              30.0.0.36: RFXCOM
              3.0.6.2: SDJ-Health
              3.0.0.87: weatherXML
              3.0.1.190: Z-Wave
                That’s an old version of the help file. The correct HS3 one is here: http://help.homeseer.com/help/HS3/st...gins_debugmode
                  I have enabled the debug logging...waiting for this to happen again.
                  I have been keeping an eye on the system more closely...I noticed this morning that HS is using a ton of CPU. Not sure why it shows up as "(system)_17-May" in top, but looking at the PID it is indeed the mono processes for HS:
                  top - 07:28:01 up 1 day, 10:09, 2 users, load average: 1.43, 1.13, 0.93
                  Tasks: 138 total, 4 running, 134 sleeping, 0 stopped, 0 zombie
                  %Cpu(s): 66.4 us, 4.7 sy, 0.0 ni, 28.7 id, 0.2 wa, 0.0 hi, 0.0 si, 0.0 st
                  KiB Mem: 1959280 total, 1830492 used, 128788 free, 3884 buffers
                  KiB Swap: 0 total, 0 used, 0 free. 77040 cached Mem
                  PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
                  1108 root 20 0 222184 74416 708 S 125.4 3.8 472:14.57 (System)_17-May
                  1585 root 20 0 124296 56108 1164 S 10.0 2.9 105:56.15 mono
                  1499 root 20 0 159328 78144 0 S 4.0 4.0 70:36.52 mono
                  1598 root 20 0 101344 38372 0 R 0.7 2.0 25:46.08 mono
                  1637 root 20 0 111564 44096 2888 S 0.7 2.3 6:37.28 mono
                  root@hometrollerSEL:/home/homeseer# ps -eaf | grep 1108
                  root 1108 1106 23 May17 ? 07:55:00 mono HSConsole.exe
                  root 1437 1108 0 May17 ? 00:06:03 /usr/bin/mono /usr/local/HomeSeer/HSPI_drhsIpPlugIn.exe
                  root 1449 1108 0 May17 ? 00:17:22 /usr/bin/mono /usr/local/HomeSeer/HSPI_BLBackup.exe
                  root 1461 1108 0 May17 ? 00:14:38 /usr/bin/mono /usr/local/HomeSeer/HSPI_EasyTrigger.exe
                  root 1482 1108 0 May17 ? 00:14:56 /usr/bin/mono /usr/local/HomeSeer/HSPI_ImperiHome.exe
                  root 1499 1108 3 May17 ? 01:10:42 /usr/bin/mono /usr/local/HomeSeer/HSPI_ZWave.exe
                  root 1528 1108 0 May17 ? 00:05:59 /usr/bin/mono /usr/local/HomeSeer/HSPI_PUSHOVER.exe
                  root 1547 1108 0 May17 ? 00:12:24 /usr/bin/mono /usr/local/HomeSeer/HSPI_BLEditor.exe
                  root 1563 1108 0 May17 ? 00:06:09 /usr/bin/mono /usr/local/HomeSeer/HSPI_DOORBIRD3P.exe
                  root 1585 1108 5 May17 ? 01:46:08 /usr/bin/mono /usr/local/HomeSeer/HSPI_AmbientWeather.exe
                  root 1598 1108 1 May17 ? 00:25:47 /usr/bin/mono /usr/local/HomeSeer/HSPI_ULTRAM1G3.exe
                  root 1619 1108 0 May17 ? 00:03:09 /usr/bin/mono /usr/local/HomeSeer/HSPI_Meiku.exe
                  root 1637 1108 0 May17 ? 00:06:37 /usr/bin/mono /usr/local/HomeSeer/HSPI_MeiUnifi.exe
                  root 1672 1108 0 May17 ? 00:01:17 /usr/bin/mono /usr/local/HomeSeer/HS3Sentry.exe
                    So I am still not having any luck here. It appears that the box is running out of memory?...all of the mono processes die when this happens and any ssh connections I have get closed. This explains why HSSentry fails to restart. It seems like HS should have HS sentry running outside of the mono process to deal with situations like this.
                    I have asked homeseer for instructions on how to upgrade Ubuntu to a more recent version as who knows what could be causing this given how out of date my original SEL is (14.04.1). I have never gotten a response. I wish I had known that I would be on my own when purchasing the SEL. I wrongly assumed that Homeseer would be supporting their product from an OS update perspective.
                      I have been running the date through a watch command to try and catch when this was happening. It looks like a memory issue for sure. Here is what my screen looked like on the last crash:
                      watch: unable to fork process: Cannot allocate memory
                      Broadcast message from root@hometrollerSEL
                      (unknown) at 5:51 ...
                      The system is going down for reboot NOW!
                      Here is what syslog shows at that time:
                      May 28 05:40:01 hometrollerSEL CRON[17492]: (root) CMD (/usr/local/HomeSeer/register_with_find.sh)
                      May 28 05:45:01 hometrollerSEL CRON[17696]: (root) CMD (/usr/local/HomeSeer/register_with_find.sh)
                      May 28 05:50:01 hometrollerSEL CRON[17888]: (root) CMD (/usr/local/HomeSeer/register_with_find.sh)
                      May 28 05:51:50 hometrollerSEL rsyslogd: [origin software="rsyslogd" swVersion="7.4.4" x-pid="451" x-info="http://www.rsyslog.com"] exiting on signal 15.
                      May 28 05:52:14 hometrollerSEL rsyslogd: [origin software="rsyslogd" swVersion="7.4.4" x-pid="451" x-info="http://www.rsyslog.com"] start
                      May 28 05:52:14 hometrollerSEL rsyslogd: rsyslogd's groupid changed to 104
                      May 28 05:52:14 hometrollerSEL rsyslogd: rsyslogd's userid changed to 101
                      May 28 05:52:14 hometrollerSEL kernel: [ 0.000000] Initializing cgroup subsys cpuset
                      May 28 05:52:14 hometrollerSEL kernel: [ 0.000000] Initializing cgroup subsys cpuacct
                      May 28 05:52:14 hometrollerSEL kernel: [ 0.000000] Linux version 3.16.0-031600-generic (apw@gomeisa) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014
                      May 28 05:52:14 hometrollerSEL kernel: [ 0.000000] KERNEL supported cpus:
                      May 28 05:52:14 hometrollerSEL kernel: [ 0.000000] Intel GenuineIntel
                      Does anyone have any suggestions on how I can figure out why my system is crashing? Hard to believe there are not more entries in the syslog but that is all that there is.
                        Run top, then press Shift-M to change the sorting to %MEM. Run for awhile and see if the top entry(s) are climbing to a large %.
                        You might try using htop instead of top, its a bit more user-friendly. If you don't have it, try adding it via
                        sudo apt-get install htop
                        Also, run this command and post results. Some of the HS Raspberry Pi builds mapped some of their file systems to RAM; they may be doing similar on the SEL.
                        df -h
                        For any entries with tmpfs in 1st column (meaning a file system living in RAM rather than disk), monitor over time to see if the Use% is growing.
                        To run that (or any command) periodically,
                        watch -n 60 -d df -h
                        The number after -n is number of seconds between updates; -d makes it highlight differences.
                        Maybe not an issue, but I see that they are logging cron jobs, which can add up over time. This can be muted by creating file at /etc/rsyslog.d/cron.conf with this contents:
                        # mute info messages generated by cron jobs
                        cron,authpriv.info
                        Then restart rsyslogd via
                        sudo service rsyslogd restart
                        or just reboot.
                        I mention this because on some of the raspi builds, they mapped /var/log to a tmpfs.
                          Thanks for the suggestions. I am continuing to keep an eye on things. I did find that the BLbackup plugin seems to be using a lot of memory even after my daily backup is complete...not sure if this is my issue but I posted in the BLbackup forum to see if anyone else has run into this:
                            Very interesting, that does seem high. Will be interested if it grows again after subsequent backup runs.
                              I manually triggered a couple of backups...looks like it is indeed growing:
