Database Repair
  • Database Repair
    Apparently, I have smoked my homeseer database. Is there some way to rebuild it?
    Don
    Check the Config/Backup folder and see if there are any in there.
      No such luck. I had been using a backup script that didn't work.
      Don
        What about the backups that HomeSeer itself makes? They're in the Data directory with the running database. There should be several of them.
          For some reason I can't find them. I thought HomeSeer automatically backed up the database, but ...
          Don
            The database copies are under Data. In Linux it is /HomeSeer/Data windows would be the same. Use filemanager and you should see them.
            Rename current one to *.bak and rename an older copy to current db name. Shut down HS3 first and...
            HomeSeerData.hsd == > HomeSeerData.hsd.bak
            HomeSeerData_14.hsd ==> HomeSeerData.hsd
            Click image for larger version  Name:	db-backup.jpg Views:	0 Size:	41.2 KB ID:	1312776
            - Pete
            Auto mator
            Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
            Homeseer Zee2 (Lite) - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
              Thanks Pete. That seemed to work.
              Don
