Background: At one point and for a long time, I was able to connect to HS3 on my local network, same subnet, via the web interface with no issues. As far as I know, the only changes were HS3 version updates. I do not recall making other changes and/or adding new plug-ins. One day I discovered that I can no longer get to the web interface via the local network. HS3 Pro is running on Windows 10 (headless). I can get to the host machine via RDP and the web interface runs fine on the HS3 machine itself. MyHS remotely works fine also. This is a dedicated machine with no 3rd-party security software running on it.
Observations/actions: I have since disabled Windows Firewall (the result is "connection refused" when I try to connect to the web interface), with Windows Firewall enabled, the browser reports connection timed out. I can ping the machine. HS3 Pro can obviously make outbound local connections because it communicates with Rachio, Ecobee, etc. on the same network just fine.
I added my subnet xxx.xxx and loopback 127.0. to the Subnet section under network settings, defaulted port to 80, but nothing has worked.
My network integrity is fine and I can connect to every other host except HS.
I have found a few threads with similar issues, but none provided a resolve.
I would appreciate any help or ideas.
Thanks.
Thanks.
