I’m doing an Add/Include of wall dimmer HS-WD100+ and I get the following error:
Error: Error, Exception enabling notifications for Express_Controls device (Node 48 Z-Wave HomeSeer HS-WD100+ Dimmer):=Object reference not set to an instance of an object Trace: at HSPI_ZWave.clsZwave.Devices_94_EnableNotifications_Express_C ontrols_HomeSeer (HSPI_ZWave.clsZWaveDevice& zd, Boolean Priority, SyncType SyncScanType, HSPI_ZWave.ControllerFunction& Res) [0x00000] in :0
I can see it in Device Management, but I can’t control it from HS3 (that is, it doesn't respond to ON/OFF buttons). I’ve added and removed several times. I don’t know what to try next.
Current Date/Time: 7/5/2019 2:12:49 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.534
Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 0 Days 0 Hours 47 Minutes 29 Seconds
IP Address: 127.0.0.1
Number of Devices: 160
Number of Events: 28
Available Threads: 199
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.1.252: Z-Wave
Add Node started...
Activate the 'Add to Network' function on the device...
A new node is being added...
DONE - Add Node Operation is Complete.
Done. Node 48 Added.
Reloading (importing) node information...
Synchronizing node information with HomeSeer and creating new device(s) as necessary...
Synchronize nodes finished. Number of device nodes to be created/added = 1
Z-Wave manufacturer information for node 48, ID: 12=CH (HomeSeer), Type: 17479=4447H, ID: 12340=3034H
Node: 48 Supports Class(es): ZWAVEPLUS_INFO, VERSION_V2, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, ASSOCIATION, ASSOCIATION_GRP_INFO, POWERLEVEL, SWITCH_MULTILEVEL, SWITCH_ALL, CONFIGURATION, SCENE_ACTUATOR_CONF, SCENE_ACTIVATION, CENTRAL_SCENE_V2, FIRMWARE_UPDATE_MD_V4
Node: 48 Controls Class(es): CENTRAL_SCENE_V2
Node 48 is Z-Wave version: Lib: 4.34 App: 5.17
Node 48 is a Z-Wave Plus node. Retrieving ZWPlus Info...
All associations for node 48 have been retrieved successfully, it supports associations on these groups: 1.
Root Node Device Node 48 Z-Wave HomeSeer HS-WD100+ Dimmer was created for node 48 on network 001F0430
2 out of 2 Child devices of node 48 were created successfully.
Finished.
Saving network information to file: ZNet_E4B4AA99.ZWave. Please wait...
Done!
Event Threads: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.1.252: Z-Wave
Add Node started...
Finished.
Done!
