Contacting HomeSeer This Week
See more
See less
Error trying to Add/Include HS-WD100+
  • Rvtravlr
    Try adding the original WD100. If it adds, go to z-wave page of device and see if you can reflash the firmware.
  • carrud
    I ended up swapping this out with a second HS-WD100+ dimmer switch and the second one worked as expected.
    The problem with the original HS-WD100+, however, lives on.
  • carrud
    Thanks for the suggestion. I performed the steps (disabling your Z-Wave plugin and the re-enable it and then do a remove on the device and then try an add again) and received no joy. Same error as previous.
    Jul-06 10:48:43 Z-Wave 2 out of 2 Child devices of node 48 were created successfully.
    Jul-06 10:48:43 Z-Wave Error Error, Exception enabling notifications for Express_Controls device (Node 48 Z-Wave HomeSeer HS-WD100+ Dimmer):=Object reference not set to an instance of an object Trace: at HSPI_ZWave.clsZwave.Devices_94_EnableNotifications_Express_C ontrols_HomeSeer (HSPI_ZWave.clsZWaveDevice& zd, Boolean Priority, SyncType SyncScanType, HSPI_ZWave.ControllerFunction& Res) [0x00000] in :0
    Jul-06 10:48:43 Z-Wave Root Node Device Node 48 Z-Wave HomeSeer HS-WD100+ Dimmer was created for node 48 on network 001F0430
    Jul-06 10:48:43 Z-Wave All associations for node 48 have been retrieved successfully, it supports associations on these groups: 1.
    Jul-06 10:48:43 Z-Wave Node 48 Association Group 1 can have 5 associations, and currently has 0
    Jul-06 10:48:42 Z-Wave Getting association information for node 48
    Jul-06 10:48:42 Z-Wave Node 48 is a Z-Wave Plus node. Retrieving ZWPlus Info...
    Jul-06 10:48:42 Z-Wave Node 48 is Z-Wave version: Lib: 4.34 App: 5.17
    Jul-06 10:48:42 Z-Wave Node: 48 Controls Class(es): CENTRAL_SCENE_V2
    Jul-06 10:48:42 Z-Wave Node: 48 Supports Class(es): ZWAVEPLUS_INFO, VERSION_V2, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, ASSOCIATION, ASSOCIATION_GRP_INFO, POWERLEVEL, SWITCH_MULTILEVEL, SWITCH_ALL, CONFIGURATION, SCENE_ACTUATOR_CONF, SCENE_ACTIVATION, CENTRAL_SCENE_V2, FIRMWARE_UPDATE_MD_V4
    Jul-06 10:48:42 Z-Wave Z-Wave manufacturer information for node 48, ID: 12=CH (HomeSeer), Type: 17479=4447H, ID: 12340=3034H
    Jul-06 10:48:42 Z-Wave Synchronize nodes finished. Number of device nodes to be created/added = 1
    Jul-06 10:48:37 Z-Wave Done. Node 48 Added.
  • Rupp
    Try disabling your Z-Wave plugin and the re-enable it and then do a remove on the device and then try an add again.
  • carrud
    started a topic Error trying to Add/Include HS-WD100+
    I’m doing an Add/Include of wall dimmer HS-WD100+ and I get the following error:
    Error: Error, Exception enabling notifications for Express_Controls device (Node 48 Z-Wave HomeSeer HS-WD100+ Dimmer):=Object reference not set to an instance of an object Trace: at HSPI_ZWave.clsZwave.Devices_94_EnableNotifications_Express_C ontrols_HomeSeer (HSPI_ZWave.clsZWaveDevice& zd, Boolean Priority, SyncType SyncScanType, HSPI_ZWave.ControllerFunction& Res) [0x00000] in :0
    I can see it in Device Management, but I can’t control it from HS3 (that is, it doesn't respond to ON/OFF buttons). I’ve added and removed several times. I don’t know what to try next.
    Current Date/Time: 7/5/2019 2:12:49 PM
    HomeSeer Version: HS3 Pro Edition 3.0.0.534
    Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 0 Days 0 Hours 47 Minutes 29 Seconds
    IP Address: 127.0.0.1
    Number of Devices: 160
    Number of Events: 28
    Available Threads: 199
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Enabled Plug-Ins
    3.0.1.252: Z-Wave
    Add Node started...
    Activate the 'Add to Network' function on the device...
    A new node is being added...
    DONE - Add Node Operation is Complete.
    Reloading (importing) node information...
    Synchronizing node information with HomeSeer and creating new device(s) as necessary...
    Finished.
    Saving network information to file: ZNet_E4B4AA99.ZWave. Please wait...
    Done!
