Just in case anyone is in the same position as me and Windows 10 just updated itself to 1903 I thought I would make a quick post on how to fix the "port in use" error.
It seems every time there is a major windows update World Wide Web Services (IIS) get re-enabled.
See this post on how to fix it: https://forums.homeseer.com/forum/ho...il-2018-update
Basically port 80 gets hijacked by World Wide Web Services and prevents HS using the default port 80. You will get this error in your startup log:
Hope this helps other users.
Marty.
Jul-19 9:01:34 PM | Warning | Error starting web server, port in use? Are you running a web server on the designated port? Edit settings.ini in the Config folder and change gWebSvrPort=## to a different port #. An attempt was made to access a socket in a way forbidden by its access permissions |
Marty.
