Counters/ Timers not working as expected when filtering events
  • Counters/ Timers not working as expected when filtering events
    Hi,
    Maybe I am missing something but in my event view, if I filter events referencing devices that are counters or timers, no events seem to appear. Is this expected? Below is an example of a timer selected that I know for a fact is associated with several events.
    Thank you!
    I just tried it, and the filter worked as I expected. Do you have other events that refer to timers that you can test for?
    HS3 Pro Edition 3.0.0.548
      Hi,
      Thank you for the reply. I do have other counters and timers that are used and I get the same result, unfortunately (not working).
        Just checked here and it works for me as well. I'm running .534 on Windows btw...
          Very odd - no idea what it could be. I am running also 3.0.0.534 (Windows). Thank you!
            The filter is for referencing the timer devices, not the actual timers. Timer devices are copies of the timers. I have that feature disabled so I don't see my timers in the event device filter. But that would be a good thing to have, filtering events by timer reference. I use timers a lot and have had some difficult bugs to chase when I accidentally referenced the wrong timer.
              To find Events using actual Timers and Counters (not the HS Devices) use Jon00's Event Viewer and Documenter. It allows you to filter on Timers, Counters, Scripts, other Events and even "Broken" Events.
              Click image for larger version  Name:	Capture.PNG Views:	0 Size:	9.0 KB ID:	1317957
              Randy Prade
              Aurora, CO
              Prades.net
