Contacting HomeSeer This Week
See more
See less
Transferring to new computer
  • #16
    Open Windows Device Manager, expand 'Ports (COM & LPT)'. What do you see?
    When you plugin/remove the device, the applicable COM port should appear/disappear in this view.
    • #17
      No COM4 in Device Manager.
      Jim Speiser
      30-year veteran of Home Automation
      Still don't know squat
      • #18
        The exact COM number isn't going to be maintained from one Windows install to the next. COM ports are assigned sequentially. The question is, does any COM port appear/disappear when your USB device is plugged/unplugged ... ?
        • #19
          No.
          Jim Speiser
          • #20
            This is pointing to a driver issue. In the device manager, expand the 'Universal Serial Bus controllers' section and try plugging/unplugging. See if anything shows up. Looking for something like 'Other Device', with a triangle exclamation point icon if memory serves.
            • #21
              OK, as usual, my computer has made a liar out of me. I was unplugging the PLM from the wall outlet. I always thought that was the same as unplugging it from the USB. Apparently not. I tried unplugging from the USB, and "USB Serial Port COM3" disappeared.
              Jim Speiser
              • #22
                OK, so now change your plugin to point to COM3 and all should be good with the world!
                • #23
                  Ah, would that it were that easy. My friend, apparently you are unfamiliar with my domicile, The Nightmare On Alpine Heights. Why, just today, I've had a printer reconfigure itself to use a public domain IP address (and work!), a taskbar moved itself to the other side of the screen...but I digress...
                  I get no errors in startup, but on the plug-in manager, the Insteon plug-in is still saying "WARNING: Please check the interface and enter the interface port information and restart HS." (In a lovely shade of amber, no less). And yes, I did change the port number in the insteon.ini file and on the insteon management page. Is there somewhere I'm missing?
                  Jim Speiser
                  • #24
                    Not an Insteon user, but do have Vista by same author. There, the COM port assignment is on the Manage Plugins page.
                    • #25
                      With the Insteon, it's on the Plug-Ins -> Insteon -> Configure page.
                      Jim Speiser
                      • #26
                        Back at it today...so I changed everything I could think of to COM3...do I need to rerun that FTDI Chip thingamajig?
                        Jim Speiser
                        • #27
                          Maybe plug it into a different USB port and you'll get back to com4 lol. Seriously though, maybe this is a com setup thing where you need to match parity bits or baud rate.
                          • #28
                            OK, now you're taking me back 20 years. Maybe I should install an MFM drive while I'm at it! I still remember how to format them - g=c:500!
                            [sigh] OK, here we go...
                            Here's a couple of properties screens for the COM3...
Name:	USB Serial Port COM3 Properties 2.png
ID:	1318095Click image for larger version
Name:	USB Serial Port COM4 Properties 5.png
ID:	1318096Click image for larger version
Name:	USB Serial Port COM3 Properties 3.png
                            Looks like the FTDI driver is already resident, which would explain why the FTDI setup program tells me it won't run, because the driver I have already is better.
                            So what am I supposed to match these settings to?
                            Jim Speiser
                            • #29
                              Just realized, I'm probably posting in the wrong forum. This stuff needs to go to Sir Mark of Insteon.
                              Jim Speiser
                              • #30
                                Screenshots show it as COM3 .... change to COM3 in the Insteon plugin and restart.
