Can't remove bad node - messing with network
    Hey all... setting up my new house and hoping you can help me.
    One of my HD200s seems to be giving me grief. I've manually reset it, then excluded and reincluded. Somewhere in there, it left a bad node (18) in my database that I can seem to remove - HS says it's still communicating.
    I manually deleted it from the device management page, but it still shows up as a node in the zwave PI/Node information.
    And i'm seeing it return when I add/exclude other devices on my network, as it rebuilds my setup. this is from a log file this morning when I excluded a switch:
    Aug-08 7:53:04 AM Z-Wave Device: Master Bedroom Light Watts Set to 11.332 (11.332 Watts)
    Aug-08 7:51:37 AM Z-Wave Device: Master Bedroom Light Watts Set to 11.339 (11.339 Watts)
    Aug-08 7:51:15 AM Z-Wave Warning Failed to retrieve Z-Wave class information for node 18, device synchronization/creation will not continue for this node.
    Aug-08 7:51:15 AM Z-Wave Cannot reach node 18, will not import any information about this node.
    Aug-08 7:51:08 AM Z-Wave Checking if we can reach node 18
    Aug-08 7:51:08 AM Z-Wave Getting class information for node 18...
    Aug-08 7:51:08 AM Z-Wave Error ZNetv2: A Z-Wave command on interface ZNetv2 did not start after two minutes and is being discarded - Z-Wave may not be operational.
    Aug-08 7:51:07 AM Z-Wave Device: Master Bedroom Light Watts Set to 11.394 (11.394 Watts)
    Aug-08 7:51:04 AM Z-Wave Device: Master Bedroom Light Watts Set to 11.385 (11.385 Watts)
    Aug-08 7:51:04 AM Z-Wave Device: Master Bedroom Light kW Hours Set to 0.22 (0.22 kW Hours)
    Aug-08 7:50:34 AM Z-Wave Device: Master Bedroom Light Watts Set to 11.332 (11.332 Watts)
    Aug-08 7:50:04 AM Z-Wave Device: Master Bedroom Light Watts Set to 11.385 (11.385 Watts)
    Aug-08 7:49:08 AM Z-Wave ZNetv2: Contacting node 1 to get supported features
    Aug-08 7:49:08 AM Z-Wave Checking if we can reach node 1
    Love any advice here!
    EDIT: just found this... worked perfectly.
    Click on the 'Home' menu, you should see the 'Device List'.
    Click on the name of the node you're trying to remove. You should see 4 tabs: Configuration, Advanced, Status Graphics, and Z-wave.
    Click on the 'Z-wave' tab.
    Click on the 'Test Connectivity' button, wait for it to report that it can't find the node.
    Click on the 'Remove Node'
