Connected, awaiting to be initialized
  • Connected, awaiting to be initialized
    all of a sudden I am getting these messages yet all the plugins seem to be working. I am on the current release of HS3.
    Is this truly an issue .. or is there something i am missing ..
    Any thoughts would be appreciated
    Do you see this issue if you restart HS3?
    -Rupp
      yes .. each time I restart HS3 now .. this occurs for each of the plugins
        Did something change on your HS3 recently to cause this? Have you tried disabling one of the plugins and re-enable it? Are there any errors in the Hs log that may help isolate this issue?
        -Rupp
          let me answer your questions one at a time
          - nothing has changed other than updating to current release and that was done this week. There was error messages re the log file were "malformed". I have corrected this since. Other than this, the environment has been relatively stable for a couple of years
          - I have reinstalled a couple plugins and once they have been reinstalled, and system rebooted, the same thing occurs
          - I will check the logs and get back to you
            I see nothing relating to an "error" in the logs, except for the Ecobee plugin and HS3 indicates that it needs to be authorized .. which has been done more than once .. see attached messages as these message windows stay on the desktop
              Go to Plug-ins->Manage
              Next to the heading 'Installed Plug-ins', uncheck 'Developer Mode'
                Is your anti-virus software now blocking the connections?
                  Thanks, it wasn't .. but perhaps it is now .. will check ..
                    anti virus was okay . but the developer check seemed to solve the problem . .thanx
