Event keeps repeating with latest release?
  • Event keeps repeating with latest release?
    Any ideas why an event i have that turns various lights on would keep repeating once invoked?
    Current Date/Time: 07/09/2019 20:44:55
    Linux version: ApplicationName='./run_command_raw.sh', CommandLine=''uname -a'', CurrentDirectory='', Native error= Cannot find the specified fileSystem Uptime: 0 Days 21 Hours 7 Minutes 36 Seconds
    IP Address: 192.168.1.210
    Number of Devices: 175
    Number of Events: 40
    Available Threads: 399
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Enabled Plug-Ins
    3.0.0.33: Ecobee
    3.0.0.34: ImperiHome
    3.0.0.60: PHLocation2
    0.0.0.45: Pushover 3P
    3.0.6413.20219: UltraNetCam3
    3.0.1.252: Z-Wave
    Please post a screen shot of the event.
    HS3 Pro Edition 3.0.0.548
      uhg i found the error when i took another look this morning as i was preparing a screenshot. user error.
      I was triggering the event based on a device being on, then first thing i do is turn that very same device on (instead of off). which i'm guessing caused it to loop.
        Check out the Event Clinic for a description of the difference between "Set" and "Changed To" triggers. A "Set" Trigger will do what you described, fire again even if the device is already at that value. Changing the trigger to "Change To" will only fire when the device has a different value, and is changed to the trigger value.
