Hs3 software and application - hangs when sending ip network string
  • Hs3 software and application - hangs when sending ip network string
    Michael McSharry
    Bob_Linux_User
    spike5884
    Steve Q
    zwolfpack
    Hello, I am using the script below to send infrared sting to a device over the ip network. The script works however if I hit the buttons a few times quickly crashes the entire application. and the following error message appears.
    ​​​​​​​Please help me I don't know what to do to solve the problem
    ' import required modules
    Imports System.Net
    Imports System.Net.Sockets
    Imports System.Text
    Sub Main(ByVal parms as Object)
    Select case parms
    Case "CENAHOMEPROJETORLIGA"
    Const Digit_9 = "sendir,1:7,1,37000,1,1,343,171,21,21,21,21,21,21,21,21,21,2 1,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,2 1,21,21,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,6 4,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,1743,343,85,2 1,2000"&vbCR
    CALL ENVIADADOS(Digit_9)
    Case "CENAHOMEPROJETORDESLIGA"
    Const Digit_9 = "sendir,1:3,1,38000,1,1,347,172,21,65,21,65,21,22,21,22,21,2 1,21,21,21,22,21,65,21,65,21,21,21,65,21,22,21,65,21,22,21,6 5,21,22,21,65,21,21,21,22,21,22,21,65,21,22,21,21,21,65,21,2 2,21,65,21,65,21,65,21,21,21,65,21,65,21,21,21,1577,347,172, 21,65,21,65,21,21,21,22,21,22,21,21,21,21,21,65,21,65,21,22, 21,65,21,21,21,65,21,21,21,65,21,22,21,65,21,22,21,22,21,22, 21,65,21,22,21,21,21,65,21,21,21,65,21,65,21,65,21,21,21,65, 21,65,21,21,21,2000"&vbCR
    Case "CENAHOMERECEIVER"
    Const Digit_9 = "sendir,1:6,1,37000,1,1,341,171,21,21,21,64,21,64,21,64,21,6 4,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,2 1,21,64,21,21,21,64,21,21,21,64,21,21,21,64,21,21,21,21,21,6 4,21,21,21,64,21,21,21,64,21,21,21,64,21,64,21,1516,341,86,2 1,2000"&vbCR
    Case "CENAHOMEVIVO"
    Const Digit_9 = "sendir,1:6,1,36000,3,1,96,32,15,16,15,16,15,32,15,32,47,32, 15,16,15,16,15,16,15,16,15,16,15,16,15,16,31,32,31,32,31,32, 15,16,31,32,31,32,15,16,31,16,15,16,15,32,15,16,15,16,15,16, 31,16,15,32,15,16,15,2576"&vbCR
    Case "CENAHOMETVLIGA"
    Const Digit_9 = "sendir,1:6,1,38000,1,1,172,173,20,65,20,65,20,65,20,22,20,2 2,20,22,20,22,20,22,20,65,20,65,20,65,20,22,20,22,20,22,20,2 2,20,22,20,22,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,6 5,20,22,20,65,20,65,20,65,20,65,20,65,20,65,20,1800,172,173, 20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,65,20,65, 20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,22, 20,22,20,22,20,22,20,22,20,65,20,22,20,65,20,65,20,65,20,65, 20,65,20,65,20,2000\r\n"&vbCR
    End Select
    End Sub
    Private Sub ENVIADADOS (Digit_9)
    Const Host = "192.168.0.251"
    Const HostPort = 4998
    Dim tcpClient As New System.Net.Sockets.TcpClient()
    tcpClient.Connect(host, hostport)
    Dim networkStream As NetworkStream = tcpClient.GetStream()
    Dim strResponse As String
    strResponse = "No response"
    If networkStream.CanWrite Then
    Dim sendBytes As [Byte]() = Encoding.ASCII.GetBytes(Digit_9)
    networkStream.Write(sendBytes, 0, sendBytes.Length)
    Dim bytes(tcpClient.ReceiveBufferSize) As Byte
    networkStream.Read(bytes, 0, CInt(tcpClient.ReceiveBufferSize))
    Dim returndata As String = Encoding.ASCII.GetString(bytes)
    strResponse = "Device responded: " & CStr(returndata)
    Else
    If Not networkStream.CanWrite Then
    strResponse = "Error: Cannot write data to the device"
    tcpClient.Close()
    End If
    End If
    End Sub
    Jean carlos Please embed your scripts in CODE tags using the advanced forum post editor. If you paste code as text, the forum will introduce additional spaces that sends people that are trying to help in the wrong direction. Alternately attach the script to the post.
      Imports System.Net
      Imports System.Text
      ' CENARIOS ESPECIFICOS  SALA HOME *-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
      Select case parms
           Const Digit_9 = "sendir,1:7,1,37000,1,1,343,171,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,21,21,21,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,1743,343,85,21,2000"&vbCR
           Const Digit_9 = "sendir,1:3,1,38000,1,1,347,172,21,65,21,65,21,22,21,22,21,21,21,21,21,22,21,65,21,65,21,21,21,65,21,22,21,65,21,22,21,65,21,22,21,65,21,21,21,22,21,22,21,65,21,22,21,21,21,65,21,22,21,65,21,65,21,65,21,21,21,65,21,65,21,21,21,1577,347,172,21,65,21,65,21,21,21,22,21,22,21,21,21,21,21,65,21,65,21,22,21,65,21,21,21,65,21,21,21,65,21,22,21,65,21,22,21,22,21,22,21,65,21,22,21,21,21,65,21,21,21,65,21,65,21,65,21,21,21,65,21,65,21,21,21,2000"&vbCR
           Const Digit_9 = "sendir,1:6,1,37000,1,1,341,171,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,21,21,64,21,21,21,64,21,21,21,21,21,64,21,21,21,64,21,21,21,64,21,21,21,64,21,64,21,1516,341,86,21,2000"&vbCR
         Case "CENAHOMEVIVO"
           Const Digit_9 = "sendir,1:6,1,36000,3,1,96,32,15,16,15,16,15,32,15,32,47,32,15,16,15,16,15,16,15,16,15,16,15,16,15,16,31,32,31,32,31,32,15,16,31,32,31,32,15,16,31,16,15,16,15,32,15,16,15,16,15,16,31,16,15,32,15,16,15,2576"&vbCR
           Const Digit_9 = "sendir,1:6,1,38000,1,1,172,173,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,65,20,65,20,65,20,65,20,65,20,65,20,1800,172,173,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,65,20,65,20,65,20,65,20,65,20,65,20,2000\r\n"&vbCR
         Case "CENAHOMERGBDESLIGA"
           Const Digit_9 = "sendir,1:7,1,37000,1,1,345,172,20,21,21,21,21,21,20,21,21,21,21,21,20,65,21,21,20,64,21,64,21,65,20,65,21,64,21,65,20,21,21,65,20,65,21,21,20,65,21,21,20,64,21,21,20,21,21,21,21,21,20,65,21,21,20,65,21,21,20,65,21,64,21,65,20,1527,341,86,21,2000\r\n"&vbCR
         Case "CENAHOMERGBFADE"
           Const Digit_9 = "sendir,1:7,1,37000,1,1,342,173,20,21,21,21,21,21,20,21,21,21,21,21,20,65,21,21,20,65,21,64,21,65,20,65,21,64,21,65,20,21,21,65,20,65,21,64,21,21,21,21,20,65,21,21,20,21,21,21,21,21,20,21,21,65,20,65,21,21,20,65,21,64,21,65,20,1533,341,86,21,3694,344,86,21,2000r\n"&vbCR
         Case "CENAHOMERGBAZUL"
           Const Digit_9 = "sendir,1:7,1,37000,1,1,344,173,20,21,21,21,21,22,20,21,21,21,21,21,20,65,21,21,20,65,21,64,21,65,20,65,21,64,21,65,20,21,21,65,20,21,21,65,20,21,21,21,21,21,20,21,21,21,21,21,20,65,21,21,20,65,21,64,21,65,20,65,21,64,21,65,20,1535,342,86,21,2000\r\n"&vbCR
      ' CENARIOS ESPECIFICOS COZINHA GOURMET --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
         Case "CENAGOURMETRGBDESLIGA"
           Const Digit_9 = "sendir,1:5,1,37000,1,1,345,172,20,21,21,21,21,21,20,21,21,21,21,21,20,65,21,21,20,64,21,64,21,65,20,65,21,64,21,65,20,21,21,65,20,65,21,21,20,65,21,21,20,64,21,21,20,21,21,21,21,21,20,65,21,21,20,65,21,21,20,65,21,64,21,65,20,1527,341,86,21,2000\r\n"&vbCR
         Case "CENAGOURMETRGBFADE"
           Const Digit_9 = "sendir,1:5,1,37000,1,1,342,173,20,21,21,21,21,21,20,21,21,21,21,21,20,65,21,21,20,65,21,64,21,65,20,65,21,64,21,65,20,21,21,65,20,65,21,64,21,21,21,21,20,65,21,21,20,21,21,21,21,21,20,21,21,65,20,65,21,21,20,65,21,64,21,65,20,1533,341,86,21,3694,344,86,21,2000r\n"&vbCR
         Case "CENAGOURMETRGBAZUL"
           Const Digit_9 = "sendir,1:5,1,37000,1,1,344,173,20,21,21,21,21,22,20,21,21,21,21,21,20,65,21,21,20,65,21,64,21,65,20,65,21,64,21,65,20,21,21,65,20,21,21,65,20,21,21,21,21,21,20,21,21,21,21,21,20,65,21,21,20,65,21,64,21,65,20,65,21,64,21,65,20,1535,342,86,21,2000\r\n"&vbCR
         Case "CENAGOURMETTV"
           Const Digit_9 = "sendir,1:4,1,38000,1,1,172,173,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,65,20,65,20,65,20,65,20,65,20,65,20,1800,172,173,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,65,20,65,20,65,20,65,20,65,20,65,20,2000\r\n"&vbCR
         Case "CENAGOURMETVIVO"
           Const Digit_9 = "sendir,1:4,1,36000,3,1,96,32,15,16,15,16,15,32,15,32,47,32,15,16,15,16,15,16,15,16,15,16,15,16,15,16,31,32,31,32,31,32,15,16,31,32,31,32,15,16,31,16,15,16,15,32,15,16,15,16,15,16,31,16,15,32,15,16,15,2576"&vbCR
      ' CENARIOS ESPECIFICOS QUARTO MASTER --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
         Case "CENAQRTOMASTERTVLIGA"
           Const Digit_9 = "sendir,1:3,1,38000,1,1,172,173,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,65,20,65,20,65,20,65,20,65,20,65,20,1800,172,173,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,65,20,65,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,22,20,22,20,22,20,22,20,22,20,65,20,22,20,65,20,65,20,65,20,65,20,65,20,65,20,2000\r\n"&vbCR
         Case "CENAQRTOMASTERTVDESLIGA"
           Const Digit_9 = "1"&vbCR
         Case "CENAQRTOMASTERVIVO"
           Const Digit_9 = "sendir,1:3,1,36000,3,1,96,32,15,16,15,16,15,32,15,32,47,32,15,16,15,16,15,16,15,16,15,16,15,16,15,16,31,32,31,32,31,32,15,16,31,32,31,32,15,16,31,16,15,16,15,32,15,16,15,16,15,16,31,16,15,32,15,16,15,2576\r\n"&vbCR
      ' MEZANINO CENARIOS LIGA E DESLIGA TUDO NO AMBIENTE --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
         Case "CENAMEZANINORGBDESLIGA"
           Const Digit_9 = "sendir,1:4,1,38000,1,1,126,62,15,16,15,16,15,47,15,16,15,47,15,16,15,16,15,16,15,47,15,47,15,16,15,16,15,16,15,47,15,47,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,47,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,47,15,16,15,16,15,16,15,16,15,47,15,47,15,47,15,47,15,47,15,47,15,47,15,47,15,16,15,16,15,47,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,47,15,47,15,16,15,16,15,47,15,16,15,16,15,16,15,16,15,47,15,16,15,16,15,47,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,47,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,47,15,16,15,16,15,47,15,16,15,47,15,47,15,16,15,16,15,16,15,47,15,2000\r\n"&vbCR
         Case "CENAMEZANINORGBFADE"
           Const Digit_9 = "sendir,1:4,1,38000,1,1,126,62,15,15,15,15,15,47,15,16,15,47,15,16,15,16,15,16,15,47,15,47,15,16,15,16,15,16,15,47,15,47,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,47,15,16,15,16,15,16,15,16,15,16,15,16,15,16,15,47,15,16,15,16,15,16,15,16,15,47,15,16,15,16,15,16,15,16,15,16,15,16,15,47,15,16,15,47,15,47,15,47,15,47,15,47,15,47,15,2000\r\n"&vbCR
         Case "CENAMEZANINORGBAZUL"
           Const Digit_9 = "sendir,1:1,1,37000,1,1,344,173,20,21,21,21,21,22,20,21,21,21,21,21,20,65,21,21,20,65,21,64,21,65,20,65,21,64,21,65,20,21,21,65,20,21,21,65,20,21,21,21,21,21,20,21,21,21,21,21,20,65,21,21,20,65,21,64,21,65,20,65,21,64,21,65,20,1535,342,86,21,2000\r\n"&vbCR
      End Select
      End Sub
             Else
                         tcpClient.Close()
             End If
             End If
      End Sub
      HTML Code:
      [HTML]
      [/HTML]
        I'll wager you are running on Linux?
        I loaded it on my test HS3-Pi system and it crashes HS3 each time it runs. The crash looks same/similar to what I reported here, while attempting to port one of sparkman 's masterworks to Linux. The problem area there was with some byte array encoding methods, which appears to be what you are doing as well.
        Here is the beginning of the crash transcript
        09:03:35:8407:[Event]->Running script in background: /opt/HomeSeer/scripts/ir.vb
        * Assertion at method-to-ir.c:3036, condition `m_class_get_rank (klass) == 0' not met
                Native Crash Reporting
        Got a SIGABRT while executing native code. This usually indicates
        a fatal error in the mono runtime or one of the native libraries
        used by your application.
        The script runs fine on my (main) Windows system. Here is what is received when clicking 'run event' multiple times as fast as I can:
        SERVER Waiting for client connection on port 5000
        Accepted New Client Connection From : 192.168.1.103, 51650
        Received from Client : sendir,1:7,1,37000,1,1,343,171,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,21,21,21,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,1743,343,85,21,2000
        Client closed connection
        Accepted New Client Connection From : 192.168.1.103, 51692
        Accepted New Client Connection From : 192.168.1.103, 51693
        Accepted New Client Connection From : 192.168.1.103, 51694
        Accepted New Client Connection From : 192.168.1.103, 51695
        Accepted New Client Connection From : 192.168.1.103, 51696
        Perhaps try rewriting your transmit routine to avoid the byte encoding stuff. It should be easy, since you're just sending out raw text.
          zwolfpack Can you help me describe transmission routine in a way that looks better? or give me tips and more details on how to do? I don't know much about scripting, I don't know what to do. I am using windows platform on a nuctrop but its processor is very weak.
            Sorry, the problem I wrote about assumed you were on Linux. I don't see an issue when running on Windows. My system isn't super powerful, but it doesn't lock up as you describe.
            On the event that runs the script, do you have "only allow a single instance to run at a time" checked or unchecked?
              zwolfpack What do I do or what function do I use in the script to read one instance at a time? i'm calling the script straight from the buttons on hstouch
                I was referring to the option checkbox available when calling a script from an event. I don't use hstouch so can't help with that.
                  I suspect that when you press the "9" button rapidly the subroutine ENVIADADOS is getting called multiple times prior to finishing the I/O. I suggest that you use the select case without the "Call" to the subroutine. The select case will fall through to the code without the CALL. You will need to restructure some code to make this happen. Every thing else looks ok. I would however, do as zwolfpack said and select the option to only allow one instance at a time in the calling event.
                  Bob
                  Update: See if the code below works for you.
                  Imports System.Net
                  Imports System.Text
                       Select case parms
                          Case "CENAHOMEVIVO"
                       End Select
                                  Dim sendBytes As [Byte]() = Encoding.ASCII.GetBytes(DIGIT_9)
                               Else
                                     tcpClient.Close()
                                  End If
                               End If
                        End Sub
