set radiator valve to temp setting
    I have a question regarding to a zigbee thermostat and a zwave heat controller (fibaro)
    I can read the thermostat settings and i have them in homeseer and i like to use it to control my fibaro zwave heat controller. (thermostat is plugwise lisa)
    So the event should look like this:
    if the termostat changes to anything then set the fibaro to "setting of the thermostat"
    is this possible?
    in short, if the thermostat is set to 17, set fibaro to 17
    ofcourse i can make 20 events for this but it would be nice if i can do it with one event
    It would be easy to do with a simple script, or if you have the EasyTrigger plugin, you can use it to set one device to the value of another. Let me know if you want to go the script route and I can post something to get you started.
    HS 3.0.0.548: 1990 Devices 1172 Events
    Z-Wave 3.0.1.262: 126 Nodes on one Z-Net
      I will check the easytrigger plugin, thank you for you're reply
