UI requests a shutdown when nobody is home?
    Can anybody explain how/why the UI requests a shutdown when nobody is home?
    Enabled Plug-Ins:
    Looks like HS3 when down and is restarting. Do you have any events or plugins that can restart HS3? How are you starting HS3 as it may be crashing and being restarted automatically.
    -Rupp
      HS made no attempt, for about 3 hours, to restart itself. I had to physically restart HS.
      Enabled Plug-Ins:
        Is your system exposed to the Internet? You don't have to be home if the UI is exposed to the world, you only have to guess the password. Or, if there are bugs in Homeseer, you may not even need that.
          May want to take a peek at your Windows event logs and see if there is anything of interest or if you can tell what it was up to.
            No, I don't expose that computer to the Internet.
            Enabled Plug-Ins:
              Nothing there, as far as I can tell....
              Enabled Plug-Ins:
                Had exactly the same thing happen to me last week, started this thread: https://forums.homeseer.com/forum/ho...utdown-problem
                Maybe there's a new bug?
                  Did you check your HS3 logs to see what was the last few lines logged?
                  -Rupp
                    It was just the normal Blue Iris & DirecTV entries. There was absolutely nothing unusual in the HS log or Windows Event Viewer.
                    It was out of the blue...
                      If HS3 was shut down it would log this fact. If the log just stops abruptly then either the system is crashing or HS3 is crashing both of which should be logged in the system event viewer.
                      -Rupp
                        i'm sorry, I misunderstood your question, yes there was a strange entry. Here is the log:
                        Oct-30 12:23:37 PM Startup ********************************************************************************
                        Oct-30 12:23:37 PM Startup HomeSeer version 3.0.0.548 Edition: HS3 Pro Starting Now
                        Oct-30 12:23:37 PM Startup Settings Loaded.
                        Oct-30 12:23:37 PM Warning HomeSeer was not shut down successfully the previous time it was started.
                        Oct-30 12:23:37 PM Startup Loading Settings
                        Oct-30 10:50:12 AM Database Finished: 398 devices, applying device changes to database...
                        Oct-30 10:50:12 AM Database Pre-Processed: 300 devices...
                        Oct-30 10:50:12 AM Database Pre-Processed: 200 devices...
                        Oct-30 10:50:12 AM Database Pre-Processed: 100 devices...
                        Oct-30 10:50:12 AM Database Saving Devices...
                        Oct-30 10:50:12 AM Info Plugin DirecTV with instance: has disconnected
                        Oct-30 10:50:12 AM Shutdown Finished shutting down all plug-ins.
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: Z-Wave
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: weatherXML
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: Sonos
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: MyQ
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: DirecTV
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: Blue-Iris
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: BLShutdown
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: BLOccupied
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: BLDenon
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-in: Alexa
                        Oct-30 10:50:12 AM Shutdown Shutting down all plug-ins.
                        Oct-30 10:50:12 AM Shutdown Shutting down plug-ins ...
                        Oct-30 10:50:12 AM Shutdown Shutdown Script Completed
                        Oct-30 10:50:12 AM Shutdown Running shutdown script ...
                        Oct-30 10:50:12 AM Shutdown Application shutdown at 10/30/2019 10:50:12 AM
                        Oct-30 10:50:11 AM Warning Request from UI to shutdown
                        Oct-30 10:50:11 AM Blue-Iris Successfully logged in to BlueIris server: BattleStar (ver 5.0.0.56) as cylon.
                        Oct-30 10:50:10 AM DirecTV INFO CMD SENT: http://192.168.1.91:8080/tv/getTuned?clientAddr=0
                        Oct-30 10:50:10 AM DirecTV ERROR Object reference not set to an instance of an object.
                        Oct-30 10:50:10 AM DirecTV INFO WebException: ConnectFailure Unable to connect to the remote server
                        Oct-30 10:49:49 AM DirecTV INFO CMD SENT: http://192.168.1.91:8080/info/mode?clientAddr=0
                        I did not initiate Warning Request from UI to shutdown, nor does anyone have access to the system. My computer is very locked down so it's unlikely it was accessed by an unauthorized person.
                          Are any of you guys seeing this issue running a HomeTroller S6 unit?
                          -Rupp
