Silly me, my fault I know, I was waiting until I had everything clean/perfect and back to the way I had it before to back it up. If that's the only answer I need to take a zen moment and think what direction I want to go next. The reason I'm rebuilding is that the restore function failed (from any backup date) after it crashed after two years. It never restored the devices names or my 200 events. I was trying to look at this as a chance to set things up cleaner. I also had a lot of devices that supported S2 and wanted to add them that way with newer Smartsticks.
Yesterday, I spent all day starting my HS3 install. I got most of my permanently mounted devices like light switches/door locks/etc done yesterday. That shows to be about 160 devices... obviously many are child devices. Today, I thought I'd take a break from that grind and start adding in other plugins like PhLocation and Nest.
At some point I noticed some devices not responding and went to my controller management and found this for every interface...
This network has no active interfaces enabled for it, and it has no objects or
HomeSeer devices tied to it. If this network will not be used again, please
use the functions at the end to remove this network and all associated
network data. (Restart the plug-in after removing the interface before
attempting the removal.)
The data base is empty as well.
Any ideas why this would ever happen?
While the interfaces still show in the comm port section of device manager HS3 never sees them.
I've rebooted, shut down the zwave plugin, changed the plugin versions, thrown holy water around...nothing changes.
Not happy...Tom
Current Date/Time: 2/15/2020 9:45:07 AM
System Uptime: 0 Days 0 Hours 15 Minutes 19 Seconds
Number of Devices: 166
Number of Events: 0
Available Threads: 800
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed: Webroot SecureAnywhere Webroot SecureAnywhere Windows Defender Webroot SecureAnywhere
In Virtual Machine: No MFG: gigabyte technology co., ltd.
Enabled Plug-Ins
3.0.2.0: Z-Wave
Not happy...Tom
Number of Events: 0
Event Threads: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.2.0: Z-Wave
