Hi,
Running HS3 3.0.0.548 for a while now. I have got the ssl server enabled on the Labs setup pageusing port 443 and when I start up HS3 it all works fine, both locally and from outside my LAN.
However, after some variable amount of time (from a few hours to a few days), the https server stops responding and I can't access the HS3 GUI using https/port 443. When this happens I can still access the GUI using http/port 80.
There's nothing I can find in the logs - is there any way to diagnose this and is it a known issue (given that it's a labs feature)?
Jon.
Jon.
