Contacting HomeSeer This Week
See more
See less
Disable logging of a device in a script
  • Disable logging of a device in a script
    I would like to turn off device logging when controlled in a script, but wouldn't mind leaving it logging in all other cases.
    I know I can disable logging of a device through the properties of the device itself, but as expected, this is global. I just want it disabled when my script runs
    Is this possible?
    Robert
    I think you can but I have not tried this. This is from the help manual
    Property NoLog() As Boolean Purpose
    This property allows you to get or set whether logging is to take place on the process this property is set from. If you set this property in a script, then all logging entries from procedures run from the script are stopped. If this property is set from a plug-in, then logging from that plug-in is prevented until NoLog is reset or the plug-in is shut-down and restarted.
    Note: Log entries (e.g. WriteLogDetail) which include a Priority value of 1 (highest) are always written regardless of the NoLog setting.
    Parameters
    Parameter: NoLog
    Type: Boolean
    Description: When set to True, logging for the process thread is turned off. Returns
    Return value: NoLog
    Type: Boolean
    Description: Provides the current NoLog setting for the process the property is retrieved from. Example
    To disable logging for the current process thread (script, plug-in, event):
    hs.NoLog = True
      Yeah thanks but it didn't work. I'm using capi in this case on an X-10 dimmer.
        Something like this should work:
        Sub Main(ByVal Parms As String)
            Dim rDV As Scheduler.Classes.DeviceClass
            Dim DV As Integer = 1234
            rDV = hs.GetDeviceByRef(DV)
            rDV.MISC_Set(hs, Enums.dvMISC.NO_LOG)
            'do a bunch of stuff
            rDV.MISC_Clear(hs, Enums.dvMISC.NO_LOG)
        End Sub
        Change 1234 to the reference ID of your device.
          Al... once again, you're my hero!
          Thanks works perfectly!
          Robert
            Great, glad I could help Robert!
