Here’s a head scratcher.
I have two identical servers, with identical operating systems. One is my primary HomeSeer server. It is running HS3 without issue for years.
I have a second test platform, which is my backup HS3 server. It also runs fine when I need it. I tasked this server with HS4 testing last October. It has been fine, rolling back and forth between HS3 and HS4 testing. It has been fine for several months. I have uninstalled and reinstalled both versions dozens of times without issue. Around the beginning of last month I began getting an error that the webserver port was in use.
“4/4/2020 9:43:30 AM ~!~Warning~!~Error starting web server, port in use? Are you running a web server on the designated port? Edit settings.ini in the Config folder and change gWebSvrPort=## to a different port #. The requested address is not valid in its context”
Now look at these data points:
This seems to prove that it is something that changed in my production HS3 environment, but I cannot envision what it could be, nor can I envision how it could be affecting two new machines, but not the production machine. I’m thinking it can only be a plug-in executable, but none of them seem to start prior to HS throwing the error. I also cannot figure why it continues to run just fine on my production server.
There must be something I am not seeing. Honestly, I may be a bit “snow blind” from looking at this problem every weekend for a month. I am just not seeing how all of the above could be true.
- This error occurs whether I start HS3 or HS4, as long as it is based on my production environment
- I can bring over a fresh copy of my HS3 installation from my production environment and I will get the error
- I can put a fresh install of HS4, without converting my production and it does not error
- I went to my office desktop machine and the results are identical, my HS3 production system shows the same error on my desktop. An in-place upgrade to HS4 shows the same error. A fresh blank install of HS4 does not error
- I can switch the port in settings (tried 81 and 8080) and I get the same error when I use my production environment under HS3 or converted to HS4, regardless of the port
- My production environment still starts and runs just fine on my production server
- I can install a backup of my production environment from January and it will run on the backup server or my desktop. A backup from March 3 or later will error on any machine.
- I tried rolling my backup server back to its state in January, in case it was a Windows update. Starting the HS3 from that backup works fine. Starting my current HS3 and any backup taken in March on the earlier O/S snapshot will error. A fresh HS4 installation runs fine.
- Importing my data from HS3 into HS4 does not cause the error.
- Netstat -a -b shows nothing on port 80 (or 81 or 8080) with or without HS running
- IIS or World Wide Web publishing service are not installed or running on any of the three machines
