I've recently come back to HomeSeer, and have run into an issue I don't recall having before...
When I access the Web interface for HS3, often, the interface comes up as Guest, which means I can't edit Plugins, settings, etc. I can logout, and re-login as one of the defined users, but I'm curious if there is a way to disable Guest.
I'm assuming its something obvious, but for the life of me I can't figure out what is happening...
( Note: I see that this is addressed in HS4 by being able to set a default user....)
