I have a garage door that is controlled from homeseer HS3 and after some trouble shooting, it appears the only variable left is Homeseer HS3 software itself.
At the beginning of the trouble shooting, I had a Linear (Nortek) GD00Z z-wave garage door opener which was working fine for years. I have a HS3 routine that "chimes" every time the garage door opens. Periodically I would a hear chime and sure enough, the garage door is open. I have confirmed in the log file there appears to be no "device control" entries where HS3 told the garage door to open but sure enough it's open anyway. Originally based on the lack of a log entry I ruled out HS3. so I did the following as part of my trouble shooting:
1) Linear GD00Z device - I removed the node from HS3. Added the node back into HS3. Re-associated the device back into the HS3 routines. A couple of hours later, garage door randomly opens.
2) Linear GD00Z - Unplugged the power to the device to eliminate any device control to the garage door. Obviously unplugging the device's power also eliminates the device responding to any HS3 control as well. After a week, garage door remained closed. Thinking Linear was a bad device, I replaced it on the weekend with a MIMOlite garage door opener.
3) MIMOlite Garage Door opener - added the device to HS3 device appeared associated the new device to the routines and it appeared to work fine. The next day, "chime" and sure enough the garage door is open again. ARG!!! Rebooted HS3 and unplugged the device from HS3 again... two days later, door hasn't opened.
4) throughout this trouble shooting process I considered the fact one of my garage door operator may have learned one of my neighbors remotes but we haven't found our door open during the time period the z-wave devices were/are unplugged.
5) In HS3, I have disabled all routines associated to the MIMOlite device; with the exception of the "Chime" if the garage door states changes to open. In HS3 turned on detailed logging of HStouch. Device is plugged in again. Now, waiting for a time stamp of the next random opening to occur.
After trying two different manufacturer's devices and the issue continues, the only variable left is HS3. Does anyone have any ideas what could be happening?
Current Date/Time: 6/1/2020 11:31:24 AM
Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 2 Days 14 Hours 9 Minutes 52 Seconds
IP Address: 192.168.1.40
Number of Devices: 249
Number of Events: 288
Available Threads: 199
HSTouch Enabled: True
Event Threads: 1
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.2.0: Z-Wave
