My hard drive went kaput, so I'm recovering my HS3 installation from a config backup. I reinstalled HS3 on a new machine and restored the config and most things work as before.
I had an android appliance running HSTouch client with some custom screen definitions I had designed and it works the same as before, but when I reinstalled HSTouch Designer on the new machine, it only has the default sample screens. It seems the HS3 backup didn't save the HSTouch xml designs.
But since the client works, I must assume the custom xml is stored in the client itself. I looked all over its storage but can't find it.
So my question is where & how can I recover the HSTouch screen definition that is currently running, so I can edit it with the Designer again?
Thanks for any insight.
