error in log
    error in log
    hi,
    can somebody point out why this sometimes occurs? it continuous even after disabling hsphone temporary;
    jun-19 11:40:58 Error Exception building dial commands for Microphone: Object reference not set to an instance of an object.
    Regards Bart
    Win7 64Bit on Intel NUCI7 with SSD
    HSPRO 3.
    Devices; 1370 Events; 691
    Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
    Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
    There is a chance of an event related to it still in action. Try and find it. (I could be wrong!)
    Eman.
      i confirmed its not an event, i suspect it to be hsphone or some plugin
      Regards Bart
      HSPRO 3.
        Can you look in the config folder and if you find a file about it either delete or remove and save it elsewhere. There could also be a file in the main HomeSeer (root folder) which could be like "hsphone.exe.config (for that am not sure because I have never used HSPhone. But check! (If it's there delete it!)
        And also you are running WeatherXML, check if it's enabled and disable it.
        Eman.
          Hmm no strange files there and no wheatherxml. When i restart hs3 its gone bu after sometime it appears however i am in the middle of adding some mqtt devices
          Regards Bart
          HSPRO 3.
            any other ideas? rjh do you maybe have a clue? It continues even after disconnecting all plugins
            Regards Bart
            HSPRO 3.
