So I have HS3 running on Win 10 which I also use as a media server attached to our TV. The default sound output set is the Samsung TV. I have just installed the speaker client, a USB sound output device and a passive ceiling speaker.
The speaker client is running and connected to HS3. The output device is set to the usb interface. Here's the strange behaviour.
If I press the TTS sample button it outputs the audio over the USB interface. But mp3 or wav files played via an event are played over the default Win 10 output device, in this case, the Samsung TV.
I seem to remember an issue like that being mentioned but I've not found the answer?
I've just tried following another post advice about using Speak to play The Wave file but that doesn't work either it still plays through the default audio device.
Any ideas?
Any ideas?
