All,
I have not seen any request for this but recently I purchased a smart air diffuser/air freshener call it what you will, this one is made by a company called Moodo - https://moodo.co/. It seems to work quite well and I've had it for a couple of weeks now, you buy little capsules to go into it and you can mix/match them as you see fit. The app allows you to create favourites to change the scent during the day.
I've created a basic HS3 (NOT HS4 - although it will probably work) plugin for it but it does rely on communication to their service to talk to their API. I've put that plugin in the updater and it is currently awaiting approval - not sure which section to put it in so I have put it in Thermostats & HVAC.
Not expecting a huge turnout for this one but if you have any success or otherwise it would be great if you could update this thread.
Download
Once it has been approved them installation is simply by installing it from the updater, please note that the Moodo service needs an account with an email/password - the plugin DOES NOT work with the Google/Facebook type login methods so please create a simple account with an email address and use that in the plugin.
Release Notes
0.0.0.1 - 13/07/2020 - Initial Version
Documentation
Please see attached (also included in the updater file in the \docs\ directory in your HS installation).
Download
Release Notes
Documentation
