I am having an odd problem with a counter in HS3. I have plenty of events that use counters without issue, but these two events are not working. When the event runs because the conditions are met or if it is manually run, the counter will not change. If I make an event dedicated to changing the counter, it does work. Any thoughts?
Neither of these events seems to change the counter (ignore that it sends the commands twice, it is a weird glitch, the device sometimes misses the command if it is sent only once):
This event does control the counter as expected:
I am totally stumped, definitely would appreciate any thoughts!
