HS3 Pro seems to only come with one voice (Anna).
    Is there a place I can download other voices. I use the Mike voice on the XP system.
    g
    No voices come with HS3. The voice you have now is supplied by Microsoft. Mike was part of AT&T voices which you may have purchased from Homeseer many years ago. That said, Microsoft Mike was also available for XP.
    Most SAPI5 voices are not free. You may be able to find Microsoft David online if you are on Win 10.
    Have a read of this thread: https://forums.homeseer.com/forum/ho...ecommendations
    Jon
      One other thing to note: HS3 on windows uses 32 bit voices, not 64 bit ones. Win10 comes with many available voices, but only a few of them are 32 bit versions. Make sure you get the correct ones.
        Here have continued to utilize the AT&T and Neospeech fonts that Homeseer used to sell way back. Interesting that Neospeech Kate sounds much like the Amazon Echo voice.
        George - know that you have used HS for a long time and thinking you purchased TTS voice fonts around 2000 or so during the times of Homeseer 1.X and 2.X eh? It would be the same voice fonts.
        - Pete
        Auto mator
        HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
        6.10.0.104
        HS4 Lite -
          Now to find them
