I recently installed quite a few HS-WD200 switches. I've got about 45 now. I make heavy use of the LED Actions, but things are NOT working well after all the recent additions. I'm not sure if it is due to volume (I sure hope not), or because of a zwave node issue. When I run a test event that changes LED 1 to blue on all HS-WX200 devices, the log shows an error like:
The issue is that I do not have a zwave Node 117. I confirm this a couple of ways.
1: Plugins > Z-Wave > Controller Management > Controller Node Information (it does not list node 117 in the "nodes in the controller" section)
2: Plugins > Z-Wave > Node Information (it does not list 117 as a node, or a neighbor for any other nodes)
Doing a Test Node Connectivity on a Network says something like "85 nodes found on the network. The following will be skipped: " and it DOES list node 117 in this list along with many others. I'm not sure if this is an old device that did not properly get removed, or what the issue is. I have had a few devices i've had to replace recently.
What is the disconnect here with what Homeseer thinks I have for zwave nodes, and what my z-net lists as nodes? How can I fix this?
Z-Wave Error Event Action Set HSWX200 action for event Scripts test led change failed for device node 117
