Speak command prevents following actions from executing?
    Hi folks, has anyone else noticed this issue?
    I'm running HS3/Hometroller Zee S2 (details below)
    I have found (and it's not always-always the case), that when I have a series of Event actions, sometimes those actions that follow a Speak command, never get executed.
    One specific example
    My lawn sprinklers event actions looked like this
    1. -speak to announce the start of watering cycle
    2. -run the watering actions
    3. -speak to announce completion of watering
    4. -(and for debugging, write a log entry)
    With the Speak action in there, sometimes lines 2-4 wouldn't run.
    When I removed the Speak entries, no problem.
    Similarly, I noticed within scripts, that if I have use the hs.Speak, then sometimes those scripts don't run again later because the log says that script is already running (and I've ensured that it's not violating any time constraints I've set).
    Once I removed the hs.Speak, the issue went away.
    Using Windows Speaker 3.0.0.10 (is there a newer one?)
    Cheers
    Steve
    Current Date/Time: 9/3/2020 12:32:14 PM
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.548
    Linux version: Linux HomeTrollerZeeS2V5 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux System Uptime: 13 Days 23 Hours 11 Minutes 39 Seconds
    IP Address: 192.168.15.10
    Number of Devices: 242
    Number of Events: 217
    Available Threads: 245
    HSTouch Enabled: True
    Event Threads: 9
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Enabled Plug-Ins
    3.0.0.5: CM15A
    3.0.0.71: EasyTrigger
    3.0.0.20: EnvCan
    3.0.2.0: Z-Wave
