After 5-10 minutes of the spinning wait graphic and a frozen system, this comes up in the log... Any ideas?
Linux version: Linux HomeTrollerZeeS2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
running command df -H
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.6G 5.2G 2.0G 74% /
devtmpfs 481M 0 481M 0% /dev
tmpfs 98M 230k 97M 1% /run
tmpfs 5.3M 0 5.3M 0% /run/lock
tmpfs 195M 21k 195M 1% /run/shm
/dev/mmcblk0p5 62M 21M 42M 33% /boot
tmpfs 486M 17M 469M 4% /tmp
tmpfs 486M 1.9M 484M 1% /var/log
tmpfs 486M 0 486M 0% /var/tmp
There's an instance of "mono" that's using 77% of memory...
homeseer@HomeTrollerZeeS2 ~ $ top -b -n 1
top - 17:37:49 up 6 days, 12:14, 1 user, load average: 0.20, 0.31, 0.70
Tasks: 97 total, 1 running, 96 sleeping, 0 stopped, 0 zombie
%Cpu(s): 6.1 us, 0.6 sy, 0.0 ni, 92.9 id, 0.3 wa, 0.0 hi, 0.1 si, 0.0 st
KiB Mem: 948016 total, 900424 used, 47592 free, 5724 buffers
KiB Swap: 102396 total, 100812 used, 1584 free, 37180 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
616 homeseer 20 0 4704 2360 2084 R 17.1 0.2 0:00.05 top
11 root 20 0 0 0 0 S 5.7 0.0 0:09.70 ksoftirqd/1
2325 root 20 0 113m 35m 2268 S 5.7 3.8 800:19.15 mono
1 root 20 0 2172 48 28 S 0.0 0.0 0:13.79 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.74 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:55.82 ksoftirqd/0
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
7 root 20 0 0 0 0 S 0.0 0.0 4:04.89 rcu_sched
8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh
9 root rt 0 0 0 0 S 0.0 0.0 0:00.82 migration/0
10 root rt 0 0 0 0 S 0.0 0.0 0:00.77 migration/1
13 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/1:0H
14 root rt 0 0 0 0 S 0.0 0.0 0:00.74 migration/2
15 root 20 0 0 0 0 S 0.0 0.0 0:09.06 ksoftirqd/2
17 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/2:0H
18 root rt 0 0 0 0 S 0.0 0.0 0:00.77 migration/3
19 root 20 0 0 0 0 S 0.0 0.0 0:09.10 ksoftirqd/3
21 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/3:0H
22 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper
23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs
24 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns
25 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 perf
26 root 20 0 0 0 0 S 0.0 0.0 0:00.59 khungtaskd
27 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback
28 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto
29 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
30 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kblockd
32 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 rpciod
33 root 20 0 0 0 0 S 0.0 0.0 0:08.61 kswapd0
34 root 20 0 0 0 0 S 0.0 0.0 0:00.00 fsnotify_mark
35 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 nfsiod
41 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kthrotld
42 root 1 -19 0 0 0 S 0.0 0.0 0:00.10 VCHIQ-0
43 root 1 -19 0 0 0 S 0.0 0.0 0:00.00 VCHIQr-0
44 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 VCHIQs-0
45 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 iscsi_eh
46 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 dwc_otg
47 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 DWC Notificatio
51 root 20 0 0 0 0 S 0.0 0.0 0:00.00 VCHIQka-0
52 root 10 -10 0 0 0 S 0.0 0.0 0:00.00 SMIO
53 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 deferwq
55 root 20 0 0 0 0 S 0.0 0.0 3:05.18 mmcqd/0
56 root 20 0 0 0 0 S 0.0 0.0 1:23.25 jbd2/mmcblk0p6-
57 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 ext4-rsv-conver
180 root 20 0 2916 4 4 S 0.0 0.0 0:00.44 udevd
301 root 20 0 0 0 0 S 0.0 0.0 0:00.03 kworker/3:1
303 root 20 0 2912 0 0 S 0.0 0.0 0:00.01 udevd
391 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/1:1H
413 root 20 0 0 0 0 S 0.0 0.0 0:00.06 kworker/2:2
453 root 20 0 0 0 0 S 0.0 0.0 0:00.28 kworker/1:1
480 root 20 0 0 0 0 S 0.0 0.0 0:00.02 kworker/3:2
483 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/2:0
523 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/1:2
524 root 20 0 0 0 0 S 0.0 0.0 0:00.08 kworker/0:2
531 root 20 0 0 0 0 S 0.0 0.0 0:00.03 kworker/u8:0
570 root 20 0 1708 20 0 S 0.0 0.0 0:59.64 logsave
582 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:1
590 root 20 0 0 0 0 S 0.0 0.0 0:00.02 kworker/1:0
593 root 20 0 9332 4516 3920 S 0.0 0.5 0:00.08 sshd
601 homeseer 20 0 9332 3436 2852 S 0.0 0.4 0:00.01 sshd
602 homeseer 20 0 6272 4616 2752 S 0.0 0.5 0:00.55 bash
1190 root 20 0 1708 20 0 S 0.0 0.0 1:00.07 logsave
1503 root 20 0 1780 96 76 S 0.0 0.0 3:36.57 ifplugd
1506 root 20 0 1780 96 76 S 0.0 0.0 0:45.87 ifplugd
1809 nobody 20 0 2048 56 40 S 0.0 0.0 0:06.22 thd
1835 root 20 0 29412 1436 900 S 0.0 0.2 0:56.03 rsyslogd
1989 root 20 0 3856 576 496 S 0.0 0.1 0:12.55 cron
2008 ntp 20 0 5632 1252 1132 S 0.0 0.1 1:01.65 ntpd
2044 messageb 20 0 3184 0 0 S 0.0 0.0 0:00.00 dbus-daemon
2089 avahi 20 0 3608 1692 1380 S 0.0 0.2 43:36.34 avahi-daemon
2091 avahi 20 0 3384 24 0 S 0.0 0.0 0:00.00 avahi-daemon
2130 root 0 -20 0 0 0 S 0.0 0.0 0:00.09 kworker/0:1H
2135 root 20 0 4928 100 0 S 0.0 0.0 0:00.10 dhclient
2192 www-data 20 0 6704 296 256 S 0.0 0.0 0:30.41 lighttpd
2194 www-data 20 0 19788 4 4 S 0.0 0.0 0:00.08 php-cgi
2251 root 20 0 6248 584 512 S 0.0 0.1 0:00.00 sshd
2259 www-data 20 0 19788 0 0 S 0.0 0.0 0:00.00 php-cgi
2260 www-data 20 0 19788 0 0 S 0.0 0.0 0:00.00 php-cgi
2261 www-data 20 0 19788 0 0 S 0.0 0.0 0:00.00 php-cgi
2262 www-data 20 0 19788 0 0 S 0.0 0.0 0:00.00 php-cgi
2264 root 20 0 2912 0 0 S 0.0 0.0 0:00.00 udevd
2271 root 20 0 3628 4 4 S 0.0 0.0 0:00.01 sudo
2276 root 20 0 1788 0 0 S 0.0 0.0 0:00.00 autostart_hs
2278 root 20 0 1724 4 0 S 0.0 0.0 0:29.01 startpar
2279 root 20 0 856m 712m 8168 S 0.0 76.9 628:15.60 mono
2281 root 20 0 3780 4 4 S 0.0 0.0 0:00.01 getty
2282 root 20 0 3780 4 4 S 0.0 0.0 0:00.01 getty
2283 root 20 0 3780 4 4 S 0.0 0.0 0:00.01 getty
2284 root 20 0 3780 4 4 S 0.0 0.0 0:00.01 getty
2285 root 20 0 3780 4 4 S 0.0 0.0 0:00.01 getty
2286 root 20 0 3780 4 4 S 0.0 0.0 0:00.01 getty
2336 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/2:1H
2420 root 20 0 55272 22m 1708 S 0.0 2.4 7:34.13 mono
10197 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/3:1H
29643 root 20 0 94624 44m 5708 S 0.0 4.8 5:59.77 mono
31126 root 20 0 0 0 0 S 0.0 0.0 0:01.94 kworker/0:0
32658 root 20 0 0 0 0 S 0.0 0.0 0:00.25 kworker/u8:2
Sep-27 5:15:12 PM | Error reading file /usr/local/HomeSeer/html/HomeSeerBackup_9_27_2020-17_14.zip: | Out of memory |
Sep-27 5:15:12 PM | Z-Wave | Device: Outside Multi-6x Sensor Temperature Set to 84.1 (F) |
Sep-27 5:15:12 PM | Warning | In ZipFile, exception opening /usr/local/HomeSeer/ConfigBackup/html.zip : Sharing violation on path /usr/local/HomeSeer/ConfigBackup/html.zip |
Sep-27 5:14:46 PM | Error | In Zip file handling: Sharing violation on path /usr/local/HomeSeer/ConfigBackup/html.zip |
Sep-27 5:14:44 PM | Error | In ZipFile, exception zipping files: Out of memory |
Current Date/Time: | 9/27/2020 5:22:58 PM EDT |
HomeSeer Version: | HS3 ZEE S2 Edition 3.0.0.548 (Linux) |
HomeSeer: | Is Registered |
System Uptime: | 6 Days 11 Hours 59 Minutes 22 Seconds |
Number of Devices: | 95 |
Number of Events: | 21 |
Event Last Ran: | Power Updates : Total Energy, Ran at 9/27/2020 5:22:52 PM |
Number of unique event scripts used: | 4 |
Plug-Ins Enabled: | Z-Wave:,Device History:,Nest: |
Modules/Threads: | 76 Modules, 44 Threads |
Available Threads: | 399 |
HomeSeer Memory Used: | 552 Mbytes |
