I'm confused, I've got 2 different sections of my devices page showing something it thinks is Node 15? What does it mean, and how do I get rid of what I think is the wrong (top) one?
I seem to have 2 different devices with same node #??
Had that happen to me, I think I fixed it by doing a test connectivity. Figuring out which one didn't respond. Did a re-scan all nodes. Deleted the one that didn't respond with a remove bad node command and then re-added it back to the network. You get a different node id but at least it straitened it out for me. Looks like HS3 burps sometimes. I can't remember doing anything special to the two devices that eventually were assigned the same node.
But one of them will respond to a Test Connectivity, The other won't that that will be your cue to remove and re-add it.
- Likes 1
Check Node Information page (Plugins->Z-Wave->Node Information) to see what it says for node 15. It'll probably be pointing to the device in your second image.
Next open the offending device's Z-Wave tab and see what node number is actually assigned. If it indeed indicates node 15 then try 'Test Connectivity' then 'Remove Bad Node'. Mouse over the Remove Bad Node button for a description.
Note: if you have multiple Z-Wave networks and these two aren't on the same network, this isn't an issue.
- Likes 1
