Button on remote control does not trigger event when pushed a second time
    Hi
    I have a small problem that should be easy to fix, but I am newbie and cannot find a solution...
    HS3 Pro Edition 3.0.0.548 running on Windows 10 Family
    I have a 8 button Z-Wave battery remote control Remotec ZRC-90US
    When I press two times button #3, the device status become, "Scene 003 Key Pressed 2 Times"
    Then, my event "XXX" triggered by "This device change and becomes..." runs perfectly
    Then, I stop XXX with another mean
    Now, if I press, again, two times button #3, the device status is already, "Scene 003 Key Pressed 2 Times"
    There is no change of status and the event does not trigger
    Any idea?
    Maybe forcing the device status to an unused state after each event? (if that is possible)
    Thank-You for your help
    Change your Trigger to "This device is set to...". Even though the value doesn't change, it is set each time you press the button.
      It works
      As simple as that!
      Thank-You
