I did a bunch of searches, found all kinds of talk of other devices...anyone have any experience with these for communication/compatibility with HS3 using a HS SmartStick+ ??
I was actually looking at them as they can be gotten relatively inexpensively and they look like the reed switch is pretty exposed so I was thinking i could solder wires to either side of the reed and attach a momentary NC switch or similar to make a cheap(er) z-wave switch.
I would probably have to notch the case for the wires (or fed out the back) if the cover has a tamper.
Any experience knowledge would be appreciated.
Thanks in advance.
Roger
Thanks in advance.
Roger
