ok, due to circumstances I decided to move my HS3 PRO setup off of my WIN10 64bit server that it was sharing with my NVR cause the cameras were taking up so much resources it was causing HS3 to sputter....for lack of a better term.
So I setup a desktop i had with a Pentium D 2.8Ghz CPU with 4GB RAM, put in a RAID1 set of 2 500GB HDD with a clean install of Windows 10 32bit and successfully moved HS over to it.
I installed HS3 from a download as a new install on the desktop.
then I shut down HS3 on the old server, copied it's directory completely to my file server.
then copied it from my file server to the desktop, maintaining the "Program Files (x86)" path from the server on the desktop even though it's now on 32-bit.
Booted up HS and let it go through it's thing, tons of errors (hardware missing mainly) but it loaded up with my settings and looked good. So to speak.
I moved the USB devices from the old server to the desktop and then after figuring out the new COM assignments, went into the plug-ins and adjusted where necessary.
Then I shut down, reboot, and launched HS3 with no errors in the startup...but it seemed sluggish.
Looking at the Performance Monitor and the Task Manager, both showed 100% CPU utilization with HS3 exe running around 50-60% itself.
When I shut down HS I get a CPU utilization of 8-10% just running. there's not really anything else on the machine yet.
Now I know i didn't load it on as good a machine as it was on, but HS should run fine on this machine with these specs .... shouldn't it?
what am i missing or did i do something wrong in the move? Any help would be appreciated. thanks in advance.
Roger
Roger
