I have been searching around and can't seem to find the answer for this, if it is even possible. Is it possible to make a JSON call to an HS3 server and run a script and pass it parameters? If so, what is the syntax? Thanks
Running script through JSON call?
I couldn't find a way to pass parameters, so I created virtual devices on the HS3 machine to hold each parameter and updated the devices with JSON calls, then another JSON call to run an event that runs the script. The script on the HS3 machine gets the parameters from the virtual devices. Here's the JSON call to run the event:
Code:Dim GetUrlHost as string = "http://192.168.143.200" 'I.P. address of remote server Dim GetUrlPort as string = "80" 'Port of remote webserver Dim GetUrlArg As String Dim page As String ' setup GetUrl variable to run remote event GetUrlArg = "/JSON?request=runevent&group=Telephone&name=Phone_CIDShowAnnounce" page = hs.GetURL(GetUrlHost, GetUrlArg, True, GetUrlPort)
Fred
HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
- Likes 3
Waking up an old thread I later discovered this
https://github.com/TheInsomniac/homeseer-jsonapi
I am using it to access my HS2 installation. I wrote a lot of custom scripts to switch my whole house audio system in HS2 years ago and they just work - so have never pulled them over the HS3 or HS4. I was able to use this modify this to setup HS2 to accept commands through JSON for running scripts.
So I am now hacking away at this approach to get a simple script call going through HS3 with JSON. It is definitely trial and error but I am hoping this will work.
Originally posted by simonmason View PostWaking up an old thread I later discovered this
If so, you can easily run a script via an ASP page. It has no JSON response but you can pass parameters.
Example Runscript.asp (place in your html directory).
Code:<!DOCTYPE html> <html> <body> <% Dim Name, Func, Parms Name = Request.QueryString("name") Func = Request.QueryString("func") Parms = Request.QueryString("parms") hs.Runscriptfunc Name,Func,Parms,False,False %> </body> </html>
http://<homeseer IP : port>/Runscript.asp?name=myscriptname.vb&func=Main&parms=hello
jon00
Any thoughts on how to run this command through runscript.asp?
192.168.2.70:86/Runscript.asp?name=Jon00RCCNMHS3.vben&func=Main&parms=8||run ||firefox.exe||https://sharptools.io/dashboard/view/<KEY>?kiosk=true -kiosk
I tried escaping the spaces and it still didn't work:
192.168.2.70:86/Runscript.asp?name=Jon00RCCNMHS3.vben&func=Main&parms=8||run ||C:\Program%20Files\Mozilla%20Firefox\firefox.exe||https://sharptools.io/dashboard/view/<KEY>?kiosk=true%20-kiosk
Thanks.
The issue is you are trying to send another URL in the parms and I suspect the second ? is causing an issue.
Maybe easier just to add a line to runscript.asp
If Parms = "Preset1" Then Parms = "8||run ||C:\Program%20Files\Mozilla%20Firefox\firefox.exe||https://sharptools.io/dashboard/view/<KEY>?kiosk=true%20-kiosk"
Then just send "Preset1" as the parms entry in the url.
@simonmason, I see you were trying to get "Sharptools" to work with HS any success?Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.19.0
Plug-Ins: AK Weather 4.0.5.25,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.7,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,Ring 1.0.0.9,SDJ-Health 3.1.1.3,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.32.0,Zigbee 4.0.11.0,Z-Wave 4.0.3.0, and Jon00 scripts.
