Since the past few days, I am regularly seeing the following error message (which makes no sense to me!) in the log :
System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count) at System.Net.Security._SslStream.StartFrameHeader(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security._SslStream.StartReading(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security._SslStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.Read(Byte[] buffer, Int32 offset, Int32 count) at System.IO.Stream.ReadByte() at .() --- End of inner exception stack trace --- at .() at .()
I am running HS3 Pro 3.0.0.548 (the last version, I believe) and have not made any system changes for some time.
The system is still chugging away, but I'd like to understand and eliminate these messages, which get picked up by Jon00's log monitor ........ and it doesn't digest the message at all.
Any ideas?
Any ideas?
