I have a very simple event that should trigger when a device (it's a z-wave wall switch) has been on for more than 1 hour. It seems straightforward enough to write the rule, but it's not triggering even if it's been more than an hour. How do I debug it - how do I find out how long HS3 thinks it's been on? I guess I could set a timer when it goes on and do it off the timer, but surely that's overkill for this simple application?
How to debug "device has been on for more than 1 hour"?
The last changed time should give you an idea. in the Device list view it's the right column. in grid view it's at the bottom.
I would also suggest you change your event time to something much shorter for testing purposes while you work out the kinks.HS4 Pro on Shuttle NC10U, Win10; Z-NET
Number of Devices: 1005
Number of Events: 293
Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
Guest
What kind of wall switch are we talking about? If it is not a ZWave+ switch (or an Instant Status switch), then the switch will not notify Homeseer when it changes state. If Homeseer is not notified, Homeseer will not start that timer.
- Likes 1
Originally posted by aa6vh View PostWhat kind of wall switch are we talking about? If it is not a ZWave+ switch (or an Instant Status switch), then the switch will not notify Homeseer when it changes state. If Homeseer is not notified, Homeseer will not start that timer.
Guest
Originally posted by mlevin77 View Post
It is a GE Z-Wave Wireless Smart Lighting Control Light Switch, On/Off Paddle, In-Wall. It used to work (shut off after an hour, according to my rule) but then stopped. I don't know if it's a hardware thing (and I can't find the breaker to "reboot it"...) or an HS3 thing.
You could check the Homeseer system log to see if the light on indication is being received by Homeseer (Menu "View" then "Log").
