"There was a problem trying to get installed apps. An error occurred while sending the request." and "Unexpectedly Failed during plugin startup: Object reference not set to an instance of an object"
I started getting this in my startup recently. I thought it was tied to a specific plugin - so I started disabling plugins that were loading around the point the error message showed but it continued. Looked at the startup log and the only thing I see out of the ordinary is about 30-40 of these commands. Happens every time I startup.
What is causing this? And is it related to the error above? Thanks.
3/5/2022 12:10:46 PM ~!~Warning~!~Dropping event callbacks due to full queue (Type: CONFIG_CHANGE) (2000 entries), system may be too busy, plugins and HSTouch may not receive all device updates
