I get notices from HS3 of the Z-Stick appearing disconnected, then about a minute later HS3 says it appears to be re-connected. A sample log is shown below. I get this error roughly every 10 minutes (but it does vary greatly). I am able to control my z-wave network, but this problem causes a lot of commands to be lost and some to be delayed.
I am running HS3 v48. I have tried this on two different Windows 8.1 PCs and also on a Windows 7 PC. Same results on all three. It had been working fine on HS2Pro with my Hometroller. Then my Hometroller totally died (no power at all). So I took the Z-stick out and tried to get it going on a PC with HS3 and this is where I am now.
Any ideas?
Dec-02 13:52:47 Z-Wave Error Zstick: The interface appears to have been disconnected or is having a communication issue. Dec-02 13:52:30 Z-Wave Warning Zstick: Appears to have been re-connected. Commands queued will now be sent. Dec-02 13:52:30 Z-Wave Warning Zstick: Appears to have been re-connected. Commands queued will now be sent. Dec-02 13:52:28 Z-Wave Error Zstick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (Zstick). Dec-02 13:51:28 Z-Wave Error Zstick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (Zstick). Dec-02 13:51:08 Z-Wave Error Zstick: A Z-Wave command on interface Zstick did not start after two minutes and is being discarded - Z-Wave may not be operational. Dec-02 13:50:28 Z-Wave Error Zstick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (Zstick). Dec-02 13:49:28 Z-Wave Error Zstick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (Zstick). Dec-02 13:48:55 Z-Wave Warning Zstick: A Z-Wave command (MEMORY GET ID, Cmd=NO_OPERATION) on interface Zstick is still in progress, 4s to timeout. (15) Dec-02 13:48:46 Z-Wave Error Zstick: The interface appears to have been disconnected or is having a communication issue. Dec-02 13:39:12 Z-Wave Warning Zstick: Appears to have been re-connected. Commands queued will now be sent. Dec-02 13:39:12 Z-Wave Warning Zstick: Appears to have been re-connected. Commands queued will now be sent. Dec-02 13:38:22 Z-Wave Error Zstick: Error, Z-Wave API Command Transmit failure - a Z-Wave command failed to be sent (interface disconnected). Dec-02 13:38:15 Z-Wave Error Zstick: The interface appears to have been disconnected or is having a communication issue. Dec-02 13:37:58 Z-Wave Warning Zstick: Appears to have been re-connected. Commands queued will now be sent. Dec-02 13:37:58 Z-Wave Warning Zstick: Appears to have been re-connected. Commands queued will now be sent. Dec-02 13:37:08 Z-Wave Error Zstick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (Zstick). Dec-02 13:37:08 Z-Wave Error Zstick: A Z-Wave command on interface Zstick did not start after two minutes and is being discarded - Z-Wave may not be operational. Dec-02 13:36:08 Z-Wave Error Zstick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (Zstick). Dec-02 13:34:55 Z-Wave Warning Zstick: A Z-Wave command (MEMORY GET ID, Cmd=NO_OPERATION) on interface Zstick is still in progress, 4s to timeout. (15) Dec-02 13:34:46 Z-Wave Error Zstick: The interface appears to have been disconnected or is having a communication issue. Dec-02 13:25:45 Z-Wave Warning Zstick: Appears to have been re-connected. Commands queued will now be sent. Dec-02 13:25:45 Z-Wave Warning Zstick: Appears to have been re-connected. Commands queued will now be sent.
Any ideas?
