When the plugin starts it should create about five devices in the devices screen, one of these devices is a disabled/enabled message sending device. Setting this to disabled means no messages can be sent (this is for people who may not wish to get messages if they are at home). By default it seems to be set to disabled, try setting it to enabled. I thought I had fixed it but I guess it is still wrong.
HS3 Pushover Plugin
Thanks for the feedback, I take it you get the message through this is just in the application? If so it does sound like an app issue and I think I have noticed similar where I have to drag the list upwards to force a refresh although leaving it a few seconds seems to do it eventually. Your best bet is to contact Pushover support and see what they say, I have found them to be pretty responsive to issues.
Originally posted by mrhappy View PostThanks for the feedback, I take it you get the message through this is just in the application? If so it does sound like an app issue and I think I have noticed similar where I have to drag the list upwards to force a refresh although leaving it a few seconds seems to do it eventually. Your best bet is to contact Pushover support and see what they say, I have found them to be pretty responsive to issues.
I'll contact them , its not so important because my dad does not have mobile internet but i noticed it that it did not fetch the messages from itself.
The rest is just great !
/// edit workingLast edited by Malosa; December 26, 2014, 10:27 AM.Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
I have posted a new version (v0.0.0.10) to the top post that does the following;
1) Multi Application Support - you can now specify more than one application
2) Fixed bug where devices were disabled by default when building the first time
3) Updated documentation explaining the above
A cautionary tale is that unless you reallyneed the two above things I would not worry about upgrading, what the plugin tries to do is move the existing single application to a new 'Default' application (be mindful changing the name of this, it could mean you having to go through all of your events and reselecting the application name) and existing events should continue working as this new default application. If you wish to add any new applications then you can add these in the configuration page and then go into your events and select the application name in the new field. Note: The scripting commands now also have a seventh index to pass in the API string (same as specified in the application page), you may need to amend any scripting stuff you have.
Any issues post them here, although if you have a large number of events it is worthwhile keeping a copy of your database config in case you need to revert to the old plugin if the new version does by chance break any events.
Originally posted by iamjwk View PostI entered in the message body field (event):
line1 \n line2 \n line3
On my android phone this apears as: line1 line2 line3
I.e. the \n does not seem to be converted to a line break. Can you fix this?
regards,
Jan-Willem
"We send the notification to Android with the newline there, but it
looks like it is stripping them out. We'll see if we can't do
something about that in a future update."
I know a good request for a feature :
like if there is a emergency message from pushover u always can send a acnowledge , it would be cool if u can use that seperatly like if the emergency message is alarm , i can acnowledge so the system knows i have seen the emergency message and the system dont call me ,
like for every programmed emergency message on a acnowledge a other trigger
now i can only use 1.Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
