Thanks for looking into this!
HS3 Pushover Plugin
_______________________________________________
HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
Originally posted by U5tabil View PostIs it possible to install this on the HomeTroller Zee?
There was a script at one time written by someone else that should work on the Zee as is but I don't really know where to look for it, you would lose any of the event actions though and need to pass all the information into the script to send the message.My Plugins:
Yeelight 3P | Nanoleaf 3P
Pushover loading error
At startup I get the error shown below.
Does this plugin require .NET 4.5 by any chance ?
4/25/2015 10:59:59 PM ~!~Error~!~Initializing plug-in(2): Pushover 3P Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
4/25/2015 10:59:59 PM ~!~Plug-In~!~Finished initializing plug-in Pushover 3P
4/25/2015 10:59:59 PM ~!~Plug-In~!~Finished initializing plug-in Pushover 3PMy Plugins:
Thanks for the input,
XP-32 HomeSeer version 3.0.0.163 HS3 Pro
I also show this error on the Plugin management page:
WARNING: Failed getting InterfaceStatus from Pushover 3P - the interface was not found in the list of active interfaces, the list may need to be refreshed.
I enabled Developer Mode but the console showed very little debug data:
Sub Main() Called
Connecting to server at 127.0.0.1...
Connected, waiting to be initialized...
[4/26/2015 10:45:09 AM] Plugin Starting
[4/26/2015 10:45:09 AM] No Need To Move APIToken
[4/26/2015 10:45:09 AM] APITokens:
Could you please explain how I can execute this remotely for diagnostic?
I may have missed something in the installation process.
Thanks for your help with this.
Sub Main() Called
Are you run any other plugins and do any of the others behave the same at all? Can you try leaving it disabled, restarting HS and leaving the other plugins to load. Then try and load it to see if it is somehow being caused by another plugin.
Also what sort of hardware is this on, is it anything specialist or very low performance?My Plugins:
Right Ok if more than one can see it I will use another method of the initio routine which may help and I will get a new version posted as soon as.My Plugins:
Clean startup with no plug-ins enaled
So I tried disabling ALL of my plug-ins and removed all scripts except the Startup script.
The system started without any warnings or errors.
I retried enabling ONLY the Pushover plug-in. It instantly gave the errors shown on the Plug-in manager/config page.
Originally posted by Kitar View PostSo I tried disabling ALL of my plug-ins and removed all scripts except the Startup script.
I retried enabling ONLY the Pushover plug-in. It instantly gave the errors shown on the Plug-in manager/config page.Originally posted by itanic View PostI'm getting the same on restart of the system. Disabling and restarting the plugin fixes it, but would like to find a solution also.
Could you try version .13 here please and see how you get on - https://drive.google.com/file/d/0B5D...ew?usp=sharing
Originally posted by ez1976 View PostHey
i am working on moving my HS3 to linux on Rasperry Pi 2
i installed the plugin but it seems that all the notification sounds on linux are missing.
is there a way to get them back
thanksLast edited by mrhappy; August 2nd, 2015, 04:53 AM.My Plugins:
Looks good so far
Stopped HS3
Copied new HSPI_pushover version over o the folder
Restarted HS3
Re-enabled the plug-in
No errors so far.
My HS3 test setup is on a very old PC. New PC is in the works. Just waiting to find the right embeddable machine.
Thanks very much with your fast response and all the help.
Greetings,
These errors appeared today in the log and I cannot find any place in Setup to configure "postback". Are these settings related to your plug-in?
Looks like a security key so I replaced key with *'s.
The only other thing I can think of is HS3's color keyword filtering of the log file.
Error In setup postback: Public member 'ColorStyle' on type '****************************' not found.
Error In setup postback: Public member 'Filter' on type '****************************' not found.
