Originally posted by The-Source
View Post
HS3 Pushover Plugin
Well i got it working, after the first boot-up i did get my devices synced but. To get it working I had to disable and re-enable the plugin again.
Here are the logs of initial configuration:
Jun-02 19:39:38 Pushover 3P Error In SoundLoad: The remote server returned an error: (400) Bad Request.
Jun-02 19:39:38 Pushover 3P Downloading sounds from Pushover
Jun-02 19:39:38 Pushover 3P Pushover User Valid - Checking Devices **Disabled At Present**
Jun-02 19:54:16 Pushover 3P Attempting to produce a client/group list...
Jun-02 19:54:16 Pushover 3P Downloaded 22 sounds from Pushover - Adding Device Default
Jun-02 19:54:15 Pushover 3P Downloading sounds from Pushover
Jun-02 19:54:14 Plug-In Finished initializing plug-in Pushover 3P
Jun-02 19:54:14 Pushover 3P Plugin Starting - Starting Thread
Jun-02 19:54:14 Info Plugin Pushover 3P has connected. IP:127.0.0.1:57367
Jun-02 19:54:06 Info Plugin Pushover 3P with instance: has disconnected
Jun-02 19:54:06 Pushover 3P ShutdownIO Called
Jun-02 19:54:06 Plug-In Shutting down Plug-In: Pushover 3P
Originally posted by ServiceXp View PostAnymore thought on my "problem"? A single event solution (what I'm looking for) would be really really great..
Originally posted by gearyt View PostJust started install, ended up with .12, but no access to config page ?Last edited by mrhappy; August 2, 2015, 04:55 AM.
Originally posted by ServiceXp View PostHere is my thinking, and I could be all wrong. In my thread about checking for device heart beat updates, a 2 event solution was suggested.
My thinking was, if Pushover could be delayed, I could possibly get away with using one event... I think in order to make that work, I need the ability to delay (and cancel) the event.
Bottom line I would like to combine these two events into one..
I'm not saying you are wrong for trying, but I am curious why I see so much effort given to reduce the number of events. -especially when it takes more time and effort to avoid the additional event than it does to build it. Multiple events are easier to track in the log, if they are carefully named they are easy to follow and annotate, delayed events are easier to cancel and events consume negligible amounts of memory and clock cycles.
Originally posted by mrhappy View PostThe config page changed from a menu page in the plugins drop down to a page that is accessed from the plugin name changing to a hyperlink in the interfaces page. That was because of a rights issue - it should be accessed like this;Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
Originally posted by rprade View PostI am curious why I see so much effort given to reduce the number of events.
Personally the number of events I have is getting out of hand. It's becoming difficult to find them to edit them down the line. All of this could be solved by having sub groups but it doesn't seem like this is going to get any traction. I hear you that it is easier to debug when you have multiple events and this is why I think sub groups is the way to go. The way it is now I'm having to create tons of groups and that gets difficult to keep track of also. This one issue is holding me back from creating a few hundred more events right now.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostPersonally the number of events I have is getting out of hand. It's becoming difficult to find them to edit them down the line. All of this could be solved by having sub groups but it doesn't seem like this is going to get any traction. I hear you that it is easier to debug when you have multiple events and this is why I think sub groups is the way to go. The way it is now I'm having to create tons of groups and that gets difficult to keep track of also. This one issue is holding me back from creating a few hundred more events right now.
I've gone to creating general groups, then additional groups under them such as- Lighting Controls - General
- Lighting Controls - Location
- Lighting Controls - Motion
- Lighting Controls - Time
- Power Controls - General
- Power Controls - Location
- Power Controls - Seasonal
- Power Controls - Temperature
- Power Controls - Time
