The application key, user key and group keys are all correct.
HS3 Pushover Plugin
Went back to v20 and messages are sent - back to v21 no messages. I am back to running v20.
Under v21 the same users or groups that are working under v20 are already selected. Just for testing I tried different users and groups, but no messages are delivered.
If you need any logs or other information, let me know.
Just loaded and enabled plugin. When I try to add the application name and key I am getting this:
Feb-23 7:13:35 PM Pushover 3P Application Verification Failed
Feb-23 7:13:35 PM Pushover 3P WebException Error: The remote server returned an error: (400) Bad Request.
I copied the API Token/Key from the pushover website so I am pretty sure it should be right. I am using v20 from the first post.
Originally posted by sonypoolplr View PostJust loaded and enabled plugin. When I try to add the application name and key I am getting this:
Originally posted by rprade View PostWent back to v20 and messages are sent - back to v21 no messages. I am back to running v20.
Originally posted by mrhappy View PostThanks for trying Randy - sorry about that I think I might have fixed it now but never know, is there any chance you could test this for me? https://drive.google.com/file/d/0B5D...ew?usp=sharing
EDIT: Actually on further thought, I will keep the groups, so I don't have to go through and find all of the Pushover actions and edit them. I may be able to change them over time, but having a group I can edit on the Pushover site is still useful.
Originally posted by mrhappy View PostI have to pass both the user key and the application key to validate the application so can you please double check both of those are updated and correct. If they are can you open the PushoverConf.ini file in your Config directory and see whether they are updating in that file OK?
Originally posted by rprade View PostIt works fine here with only a few tests. I tried all of my individual devices, then a few of them, all of them and my group. All work as expected. The only small suggestion is it would be better if the list is sorted. Probably not a problem, I have a total of 8 items, 2 groups and 6 devices, but it is displayed in random order. I will be able to get rid of the groups now, so I will be down to 6, making the sort order less important.
Originally posted by sonypoolplr View PostI have the user key in, and I believe it was taken, I am getting the error when I try to put the application name and key in. I will check the ini file tonight for you.
I keep getting "Object reference not set to an instance of an object" in the log.
Application Keys and User Key are setup correctly. Nothing happens on my phone.
Feb-28 11:19:03 PM Pushover 3P Unknown Exception in Pushmessage: Object reference not set to an instance of an object.
Feb-28 11:19:03 PM Pushover 3P Resending Pushover Message
Feb-28 11:19:03 PM Device Control Device: Pushover 3P Pushover 3P Last Message Sent to Resend Message (1) by/from: CAPI Control Handler
Originally posted by mike2016 View PostI keep getting "Object reference not set to an instance of an object" in the log.
Originally posted by mrhappy View PostDoes sending a message by an event action work OK?
I first created a manual event (IF triggered manually), THEN send a pushover message to all devices. i manually triggered it, shows up on LOG but nothing happens on my phone.
My phone works properly(iPhone), I added another device(my desktop) and my phone instantly shows a notification that another device had been added to the account.
Originally posted by mrhappy View PostHmm - I can't think of what that might be at the minute because the exception is unhandled and thought I had managed to catch most of the obvious ones. Can you please show me what the event looks like (attach a screenshot) when you have pressed the update button. Also could I ask that you restart the plugin if you have not tried already.
thanks!
