Originally posted by gsegovia15
View Post
HS3 Pushover Plugin
Originally posted by mrhappy View PostThe plugin has just one file, HSPI_PUSHOVER3P.exe, that file needs to be in the directory you posted with all of the other plugin files that all start HSPI_ that's the way HS finds the plugins. Providing it is in this directory when you go to the plugin page it should be in there and you can enable it.
Originally posted by mrhappy View PostHopefully someone else can put a real life spin on this but I did have Pushover on a partners phone and just logged in with my Pushover login (the app has it's own login screen) and then had two devices in HS, albeit my partners phone was Android rather than iOS so don't know how to change this.
I think the idea of groups is more if say you ran an IT department and wanted separate users who did not share login details, as it's someone in your house that shouldn't be as big an issue.
I went ahead and bought an in-app license on my iPhone which I could reuse on my wife's iPhone. We're now using a shared Pushover account where we have one device each defined. I can now send individual messages or group messages. Very nice!
Originally posted by mmoud View PostThis is working great on HS3Pro Linux. This should be part of official build . Thank you so much for developing this plugin.
Why don't you make this part of official plugin list ?
Originally posted by mrhappy View PostThank you for the feedback and glad it is of use to you, in terms of the last question there are a few posts about it on this thread but basically the HS policy is clear (http://www.homeseer.com/3rd-party-de...on-policy.html) - "However, free add-ons will not be listed in the updater and will not be promoted through our online store. Authors of free add-ons are not eligible for developer support through HST", their adherence to the policy appears less clear as there are plugins in the updater that are free. I did send a message asking for clarity and consideration of inclusion but did not get a reply.
Sent from my Nexus 6P using Tapatalk
Originally posted by sparkman View PostHi Adam,
Is there a way to retrieve the available Device/Group listing and the available sound listing through scripting commands?
Al
Originally posted by mrhappy View PostAl, although I have not tried it in a while (it should still work) there is the function if you call PluginPropertyGet of returndevices, that should recover a list of devices/groups setup in the plugin. I can add a list of sounds if you wish but it would only be the same as you can get by calling https://api.pushover.net/1/sounds.json?token=(your app token) as the list never changes.
AlHS 4.2.8.0: 2134 Devices 1252 Events
Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
Originally posted by sparkman View PostThanks Adam, will give that a try. For the sounds, I'd like to incorporate a drop down in the configuration page for my lock events script (http://board.homeseer.com/showthread.php?t=172326) rather than a person having to type in the value. If I could query the plugin, then the web page does not need to know the app token.
Al
Originally posted by mrhappy View PostOk no problems I can see a value in adding it then, could I ask whether you can check whether the other command works first? If that does not work then I'll fix that as well - they were added for integration with WeatherXML.
Cheers
Originally posted by sparkman View PostThanks Adam, yes, returndevices works great.
Cheers
Al
Code:Sub Main(ByVal Parm As Object) Try Dim sounds() as String sounds = hs.PluginPropertyGet("Pushover 3P", "", "returnsounds", nothing) For each sound as string in sounds hs.writelog("Pushover Sound", sound) next Catch ex As Exception : hs.writelog("", "Exception: " & ex.message) End Try End Sub
Originally posted by mrhappy View PostAl - I've posted version .27 in the top thread, the function is returnsounds and should work based on my testing. Let me know if you need anything additional or if there are any issues.Will try it later today and let you know.
Cheers
Hi Adam,
Works great. Thanks again!
I have a question related to the 'PushScript' plugin function. For the Device Name/Index(0) in the array, can multiple devices be passed to it? If so, what's the syntax for it?
Al
