HS3 Pushover Plugin
Originally posted by ghlacy View PostDec-28 6:30:00 AM Pushover 3P Unknown Exception in Pushmessage: Object reference not set to an instance of an object.
Can anyone help me out?
Embed images in Pushover messages
Installed the plugin, great to see it just works and does what it promises to do. Thanks for the good work!
Currently I have a setup that sends a picture from the webcam at the door the moment the doorbel rings. I am using e-mail and a small script to do so.
I am wondering if this is something I could with Pushover.
Here are my thoughts:
- If I understand correctly I cannot attach any images to a pushover message.
- I believe it is possible to add URL's to a Pushover message that can be opened automatically using the option "Auto-open URL's"
- I do not want to have a URL that points to my internal (home) storage because of security
To make this happen I have the following challenges:
- I will have to use an intermediate platform like eg. Onedrive to store the captured images
- What would be the best way to copy a file from homeseer to Onedrive?
- How do I preserve the URL, insert it in the pushover message and open it automatically?
Open for brilliant ideas !
Francois
Originally posted by fvhemert View PostInstalled the plugin, great to see it just works and does what it promises to do. Thanks for the good work!
Francois
1) Run a very small web server dedicated to this task of hosting the images, that way it is a bit more simple to copy a file from a HS script into the web server directory that allows you more control. Downside is all the issues around hosting, port forwarding, security etc.
2) Upload it to web space, should be possible with the hs.ftp command (if it works) to upload an image then you can point to it in a Pushover message. Then you have to worry about cost, subscriptions to hosting companies.
In terms of OneDrive, Google Drive, DropBox then I've also thought of this but the option of using say the desktop client and just copying a file then it would be a worry of mine about whether the image you are viewing is actually the image you wish to see. From my experience with Google Drive it seems to be quite slow to upload files, there may be options in terms of .net libraries that offer assurances of the uploaded files being actually there.
The other consideration may be PushBullet - I think that supports sending images but you'd need to do a bit of research as I don't know anything really about it.
HS3 298 freezes for 3 minutes with Pushover 27
As the title suggests, I'm trying to use version 27 of the Pushover plugin with HS3 298. I can receive push notifications, but they come 3 minutes after I manually trigger the event and during those 3 minutes, HS3 is completely unresponsive. Here are what the logs look like:
Dec-29 10:14:46 AM Event Event Trigger "Notifications Push Test Event"
Dec-29 10:18:50 AM Pushover 3P Pushover Notification Sent - Message Title: Testing
Any thoughts on what is going on during those three minutes and how I might correct the issue?
Thank you for your help.
Originally posted by Beltane View PostAs the title suggests, I'm trying to use version 27 of the Pushover plugin with HS3 298. I can receive push notifications, but they come 3 minutes after I manually trigger the event and during those 3 minutes, HS3 is completely unresponsive. Here are what the logs look like:
Originally posted by mrhappy View Post2) Upload it to web space, should be possible with the hs.ftp command (if it works) to upload an image then you can point to it in a Pushover message.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
Originally posted by mrhappy View PostI'm afraid I'm going to need a bit more - when you load the plugin does it give any errors? Does the HomeSeer log show any success at downloading the sounds from Pushover (should say how many sounds it has managed to download). Usually this points to incorrect details in the config page.
Dec-29 1:59:04 PM Pushover 3P Downloading sounds from Pushover
Dec-29 1:59:03 PM Plug-In Finished initializing plug-in Pushover 3P
Dec-29 1:59:03 PM Info Plugin Pushover 3P has connected. IP:127.0.0.1:50217
Dec-29 1:58:53 PM Plug-In Found plug-in: Pushover 3P, version: 0.0.0.25
does this help?
Originally posted by mrhappy View PostNo and it's not something I've seen before or been reported to me, can I ask what other plugins you are running on the system and what type of system is it (Linux/Windows)? It may point to a issue with HS being locked due to something playing up - do other events with the plugin disabled still run OK?
Ecobee 3.0.0.13
HSTouch Server 3.0.0.68
ImperiHome 3.0.0.13
MCSSPRINKLERS 2.17.0.0
Nest 3.0.0.21
PHLocation 3.0.1..52
Pushover 0.0.0.24 (It was 27, but I went back to the one that worked for me in July, though it has the same issue. Of course, I was running a different version of homeseer then.)
Z-Wave 3.0.1.87
It is a Windows 10 Pro, build 10586.
BTW, I just disabled everything except for Pushover and Z-Wave and the same thing happens.There is nothing in the logs between the event and the pushover log line. All I have, for example, is:
Dec-29 4:46:01 PM Pushover 3P Pushover Notification Sent - Message Title: Testing
Dec-29 4:41:57 PM Event Event Trigger "Notifications Push Test Event"
Originally posted by ghlacy View PostDec-29 1:59:04 PM Pushover 3P Downloaded 22 sounds from Pushover - Adding Device Default
does this help?
Originally posted by Beltane View PostI am using:
Ecobee 3.0.0.13
ImperiHome 3.0.0.13
Nest 3.0.0.21
Z-Wave 3.0.1.87
If you wish to send me an email through the message board I can take a look at your debug log in a bit more detail and find where the problem might lie.
Thanks for your answers.
Originally posted by mrhappy View Post1) Run a very small web server dedicated to this task of hosting the images, that way it is a bit more simple to copy a file from a HS script into the web server directory that allows you more control. Downside is all the issues around hosting, port forwarding, security etc.
Originally posted by mrhappy View Post2) Upload it to web space, should be possible with the hs.ftp command (if it works) to upload an image then you can point to it in a Pushover message. Then you have to worry about cost, subscriptions to hosting companies.) but there are products around (eg. https://www.smartftp.com/client/editions ) that offer this. Will invest some time in finding out if there is a reliable and affordable alternative.
Originally posted by mrhappy View PostIn terms of OneDrive, Google Drive, DropBox then I've also thought of this but the option of using say the desktop client and just copying a file then it would be a worry of mine about whether the image you are viewing is actually the image you wish to see. From my experience with Google Drive it seems to be quite slow to upload files, there may be options in terms of .net libraries that offer assurances of the uploaded files being actually there.
Originally posted by mrhappy View PostThe other consideration may be PushBullet - I think that supports sending images but you'd need to do a bit of research as I don't know anything really about it.
Originally posted by ghlacyDec-28 6:30:00 AM Pushover 3P Unknown Exception in Pushmessage: Object reference not set to an instance of an object.
Same info in log, 22 sounds downloaded and everything looks correct in the config page.
