Originally posted by mrhappy
View Post
HS3 Pushover Plugin
I have checked here, but the event just looks normal to me, nothing changed.
BTW the message arrived here, but only after 30 minutes or so, quite slow. This morning other messages arrived immediate again, so I gues it was mainly coincidental it was delayed.
But the error on the attachment remains on every message that is send from here:
jan-30 08:25:27 Pushover 3P Attachment does not exist - check path/file status and try again - will send plain message
Here is a sample of event that triggered this morning, I never changed it?
Wim-- Wim
For testing I pressed the update button on the above event. Then I triggered and the error was gone. I hope this can be resolved without updating every event?
Wim-- Wim
Originally posted by w.vuyk View PostFor testing I pressed the update button on the above event. Then I triggered and the error was gone. I hope this can be resolved without updating every event?
Wim
The fact this event had an issue might just be that there was some old data in the attachment box. I guess even a single space character may cause that so I'll put a little check in so it ignores anything less than three characters.
How to attach a photo?
I'm trying to attach a photo to a message. The photo is located on my Synology NAS. And i use the following link: nfs://192.168.2.9/volume1/photo/Camera's/Voordeur.jpg
When the event triggers, i constantly get the error:
And i recieve no photo in my Pushover notification.
Can you tell me what i'm doing wrong?
Problem solved: it was my bad, i had the wrong string. I had to use the directory on my pc, where my homeseer runs, instead of my mac.Last edited by michaeldecharon; January 31, 2018, 10:58 AM.
Originally posted by mrhappy View PostI kind of hoped it would be fine with Linux as it is fairly standard but I guess I have been proved wrong. I will do my level best to fix this but it might take a bit of time because I'm going to have to get a VM back installed.
It's finding the file and looks to be making half a go of it which is good at least, the fact it's not a 400 series error should help a bit so it could be a difference in encoding between the two platforms. For now I'm afraid you will have to make do with just sending messages the old way, when no text is sent in the attachment field the message gets sent by the old method.Originally posted by alan_smithee View PostWhen I try to send an 189K image I get the following error.
Code:Jan-29 18:49:40 Pushover 3P Error POST URL The 'meta' start tag on line 6 position 4 does not match the end tag of 'head'. Line 9, position 3. Jan-29 18:49:40 Pushover 3P Web Exception Response Pushover Uh oh An error occured on our server while processing your request. Please try again later. Pushover is a trademark and product of Superblock, LLC. Copyright © Superblock, LLC. All rights reserved. Jan-29 18:49:40 Pushover 3P WebException Error The remote server returned an error: (502) Bad Gateway. Jan-29 18:49:39 Pushover 3P Finished Uploading File Attachment: /etc/HomeSeer/html/images/camera/1.jpg Jan-29 18:49:39 Pushover 3P Sending Pushover Message Attachment - /etc/HomeSeer/html/images/camera/1.jpg
any ideas?
Is there anyone else running this on Linux and has the message attachments working - if so would you be able to tell me which version you are on?
Originally posted by mrhappy View PostIs there anyone else running this on Linux and has the message attachments working - if so would you be able to tell me which version you are on?
Still the same issue
Code:Feb-01 13:03:29 Pushover 3P Error POST URL The 'meta' start tag on line 6 position 4 does not match the end tag of 'head'. Line 9, position 3. Feb-01 13:03:29 Pushover 3P Web Exception Response Pushover Uh oh An error occured on our server while processing your request. Please try again later. Pushover is a trademark and product of Superblock, LLC. Copyright © Superblock, LLC. All rights reserved. Feb-01 13:03:29 Pushover 3P WebException Error The remote server returned an error: (502) Bad Gateway.
I found a workround that works for me:
/usr/local/HomeSeer/scripts/pushover-doorbell.sh
(remember "chmod +x")
HTML Code:#!/bin/bash curl -s \ --form-string "token=TOKEN" \ --form-string "user=TOKEN" \ --form-string "message=DING! DONG!" \ --form-string "title=DING! DONG!" \ -F "attachment=@/ftp/files/doorbell.jpg" \ https://api.pushover.net/1/messages.json rm /ftp/files/doorbell.jpg
Originally posted by alan_smithee View PostI've just installed Mono JIT compiler version 5.4.1.7 (tarball Wed Jan 17 20:11:56 UTC 2018 on my test VM.
Originally posted by ZoRaC View PostMono JIT compiler version 5.4.1.6
Ubuntu 16.04 (32-bit)
Originally posted by aponte2 View PostI am not able to get the attachment working via scripting.
I added it as noted in updated docs and always get the message in log cannot find attachment, sending plain text. I tried simple path like c:\file.png.
I have since reverted the plugin version.Originally posted by alan_smithee View PostNo problem, thank you very much for looking into this.
https://drive.google.com/file/d/1X-7...ew?usp=sharing
Not sure if I'm doing this properly but I downloaded v .38, disabled the plugin, copied the new version to HS, enabled the plugin and rebooted HS for good measure.
Downloaded the latest version of PushOver on my iPhone. I receive the message but it has a generic image icon.
Haha, just figured it out. I had to click the icon to see the image! Do you know if the image can be shown automatically, without having to click on it?
BTW, I'm on Linux HS 409, Mono 5.0.1.1.
Originally posted by rileydogmi View PostJust FYI - I see in an earlier post someone asking if there was a way to respond to a pushover notice. I got that to work by embedding a JSON request as a webURL in the message body text - it even works remotely using the myhs service so I can be outside my network to initiate events.
Really nice so I can push issues and ask actions.
for example I have a push message:
HTML Code:I noticed you left the house without setting the security system. Should I set the system for you? Press here to arm the security system
I see several situations I can use it for immediately!
thx for the help!
