Thanks, now works.
HS3 Pushover Plugin
Kinda getting closer to a two way conversation, with the feedback loop....
By the way; how does one put a carriage return in a message?Last edited by donstephens; February 10, 2018, 03:46 PM.Don
Hi all,
can somebody maybe tell me what i'm missing in this script ?
it say's expression expected but can't find the error
PHP Code:hs.PluginFunction("Pushover 3P", "", "Pushscript", New Object() {& clientsPush, "test: "& strTomorrowValue " test2 ",& TitlePush ,& PriorityPush ,& SoundPush , Nothing, Nothing,& ApplicationPush ,nothing})
regardsPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
regards
My script looks a little bit different.
Code:Sub Main(parm As Object) Try Dim ZwaveMsg As String = hs.GetVar("syslogzwave") Dim CO(8) As Object CO(0) = "iPhone" 'must be matched with a device name already in the plugin or 'All Clients' CASE SENSITIVE CO(1) = "Zwave Failed" 'message body CO(2) = String.Format("Failed to send command to " & ZwaveMsg) 'message text CO(3) = "normal" 'low/normal/high/emergency CO(4) = "System Default" 'message sound from list already in HomeSeer - must match CO(5) = Nothing 'Message URL CO(6) = Nothing 'Message URL CO(7) = Nothing 'API String CO(8) = Nothing 'Atachment hs.PluginFunction("Pushover 3P", "", "Pushscript", CO) Catch ex As Exception hs.WriteLog("Error", "Exception in script: " & ex.Message) End Try End Sub
Hi thanks for reply,
i have already 8,
This is what i have
here i put the numbers.
hs.PluginFunction("Pushover 3P", "", "Pushscript", New Object() {& clientsPush=0, "test:=1 "& strTomorrowValue " test2 ",& TitlePush=2 ,& PriorityPush=3 ,& SoundPush=4 , Nothing=5, Nothing=6,& ApplicationPush=7 ,nothing=8})
regards
Originally posted by alan_smithee View PostI think you need another ,Nothing because of the new attachment feature. I had the same issue.
also doesn't work
regards
be
"test: "& strTomorrowValue & " test2 "
?Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
after a long sleep i finaly got it
i needed to delete the &
PHP Code:hs.PluginFunction("Pushover 3P", "", "Pushscript", New Object() {clientsPush,TitlePush,"test1 "& strTomorrowValue &" test2 ",PriorityPush ,SoundPush , Nothing, Nothing,ApplicationPush ,nothing})
Last edited by Malosa; February 17, 2018, 05:04 AM.Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
Originally posted by deanrparry View PostJust a little bug fixable? not sure!
When cloning an existing event the pushover data vanishes each time... if you have a lot of similar events to create it can get annoyingcould this be fixed?
I think that it's to do with the unique ID's between events that persist when you copy an event. Because that ID changes but the data stays the same that's why you don't see the data when you copy it. I couldn't really see a way of doing it and changing the UID and im afraid I'm loathed to mess too much at the risk of trashing peoples events.
Sending Images possible?
Hello. I saw an update for "Pushover" at the Appstore on the iPhone this afternoon. It should now be possible to send images, for example from a security camera. This is a feature I've been waiting for. So far I have only sent a link to my phone. Is it possible with the plugin without a script? With kind regards, Joesch
https://updates.pushover.net/
Originally posted by joesch View PostHello. I saw an update for "Pushover" at the Appstore on the iPhone this afternoon. It should now be possible to send images, for example from a security camera. This is a feature I've been waiting for. So far I have only sent a link to my phone. Is it possible with the plugin without a script? With kind regards, Joesch
https://updates.pushover.net/Last edited by randy; February 23, 2018, 09:56 PM.
