Originally posted by joesch
View Post
HS3 Pushover Plugin
Originally posted by joesch View Postthank you very much :-)
I did something wrong with the path. I took a path over http. That doesnt work. It seems the file has to be stored local.HS4 Pro, Windows 10 pro
Originally posted by mrhappy View PostIf you have upgraded (to .37 or later) then I am afraid there is an extra parameter that is needed on the script call. This is the path for the file if you wish to send an attachment, add another nothing onto it after AI Emergency and see if that works.
Originally posted by bsobel View PostPlease please please create a new function next time you need to modify the call. I spent hours debugging the lock scripts because of this, an API should NOT change after being published.
Originally posted by mrhappy View PostPoint taken for the future, please keep in view that I am not an API designer (nor am I a programmer for that matter), earn nothing from this work (the image implementation probably took me 40+ hours to sort) and do my best to satisfy everyone which might mean things go wrong from time to time.
I have upgraded to version 0.38 and am having issues with the delivery groups. I have set up 3 delivery groups. An event that triggers a PushOver message to a single delivery group or all clients works fine and I've tested on the same event with all three groups individually. By works fine I mean the message reaches the intended devices. My issue is any event that has more than one group selected will only send the PushOver message to one of the groups.
I have triple checked the group keys in PushOver.net and the HomeSeer Plug In and like I said an event can trigger a successful PushOver message any of the 3 groups when only 1 group is selected.
What can I troubleshoot now or is this a known bug?
As a side note though I love the plug in! Keep up the good work.
Originally posted by kungfujosh View PostI have upgraded to version 0.38 and am having issues with the delivery groups. I have set up 3 delivery groups. An event that triggers a PushOver message to a single delivery group or all clients works fine and I've tested on the same event with all three groups individually. By works fine I mean the message reaches the intended devices. My issue is any event that has more than one group selected will only send the PushOver message to one of the groups.
Messages Disabled in Pushover Device
I have been using the pushover plugin for a few years now without any issue.
However, last weekend I was testing some new events and accidentally caused about 200 pushover messages to be sent from HS through the plugin. I was able to stop the event but ever since then I have not been able to get any pushover messages to send from Homeseer, receiving this error in the log, "Messages Disabled in Pushover Device".
I ran through all the FAQ steps on Pushover's website to restore/unblock my ios devices but realizes they weren't actually blocked since I was still receiving pushover alerts from other (non-homeseer) applications. I still ran through the steps including deleting the app, manually setting the ios device 2 days ahead and reinstalling the device.
I suspect there is something blocked in the plugin but I can't figure out what.
I have uninstalled and reinstalled the plugin, deleting the config.ini file with no luck. I even created a new Pushover application to test with but still get the same blocked message.
Can someone help me walk-through things to check or do to restore this HS pushover plugin?
Originally posted by Sinandgrin View PostI have been using the pushover plugin for a few years now without any issue.
Originally posted by rprade View PostYou have 2 virtual devices, both have to be on to deliver non-emergency messages. Are they both enabled?
[ATTACH]67776[/ATTACH]
Thank you rprade! I will remember for next time.
Originally posted by Sinandgrin View PostOMG, I didn't even know these existed, but that was the issue. It was set to Disabled.
It's sort of a protection measure to stop spamming Pushovers website, the plugin and also clearing your account of your free messages (about 7000 a month which the plugin could do in a minute or two if the events were set badly). It sounds like in this situation it has done exactly what it was designed to do but perhaps not quite clear that it had done so.
Originally posted by mrhappy View PostI'll put it on the list to sort out with a bit clearer logging but just to explain what it sounds like you have done is because of that event creating so many messages the plugin is set to check how many messages you send over what time period and if they are excessive it will disable itself.
Cannot select Device/Group
I just installed Pushover version 0.0.0.38 (from HomeSeer updater).
When I create a "Pushover 3P: Send Pushover Message" action, I select the device that I want to send a message to (by putting a check mark next to the device). When I close the "Device/Group" drop down, the device that I selected does not show up next to "Device/Group". The drop down menu still says "Select Devices(s)/Groups" and does not show the device that I selected (see first snapshot, attached). When I collapse the action, the "Device/Group" says "All Clients" (see second snapshot, attached).
I'm using a Mac. I've tried Safari, Chrome, and Firefox, and they all exhibit the same behavior; i.e. I cannot select the pushover device/Group to send a message to. The other drop-down type menu items in the HomeSeer GUI work just fine with the browsers that I use, except the Pushover 3P's "Device/Group" drop-down.
I also have the same problem on a Windows 10 PC using the Edge browser.
Any suggestions?
