Originally posted by Pricey1985
View Post
HS3 Pushover Plugin
Originally posted by mrhappy View Post
Well thats me eating my words already, do you have anything unusual in your network setup on your HS PC - multiple gateways, VPN connections etc? I will put together a short test script to test if thats OK which will determine whether or not the issue is in the plugin or could be elsewhere.
One is setup as an access point for all wireless connections.
HS pc is using this wireless access point.
Guest
Trying to access the documentation referenced on the store page to set this plugin up. The link is http://seriousface.ddns.net/plugins/...#Pushover%203P but that seems to be currently down?
Originally posted by Pricey1985 View Post
Thanks MattL0
Originally posted by Dan-O View PostIs there a way to automatically reset the Pushover message count at the beginning of the month?
Edit:
OK, this is weird, it did reset. I guess I never saw it on the first of the month last month.
Once message limits have been reached, requests will be rejected with a 429 HTTP status code. Message limits are reset at00:00:00 Central Time on the 1st of each month. Per-day and per-month usage statistics can be viewed on each application's page, as well as through HTTP headers returned in each API call to the messages endpoint showing your app's monthly message limit (plus any additional purchased capacity), the number of messages sent this month, and the Unix timestamp of when the count will reset.
X-Limit-App-Limit: 7500
X-Limit-App-Remaining: 7496
X-Limit-App-Reset: 1393653600
Hi
i moved my homeseer from windows to linux and my pushover for some reason is not working on some places.
i have a weather push that goes through and a news update that i had to trim otherwise it didnt arrive on my cell.
now i am trying to send an attachment file. when sending without the file, the push goes through but when attaching the file i get "Error POST URL Data at the root level is invalid. Line 1, position 1.".
any ideas?
any ideas?
Originally posted by ez1976 View PostOf Course.
here is the event in full.
